2004 GX - NAV, Pwr Locks and VSC stopped working
My wifes 04 GX freaked out today. The power locks will not work unless the IGN is in the run position. It also made just the auto driver down stop working; other 3 windows still work. The VSC lights came on and the NAV stopped working all at the same time. It still runs and drives fine, but obviously, something is not right.
Anyone have any ideas as to what the common link in all of these systems might be?
First Disconnect your Battery ( -) Terminal for 10 minutes and Reconnect. Ensure the IGN key is out of thekey slot. After the reconnection, Do not start the truck, Turn One slot of the IGN key to ACC. And wait for a 5-15 secconds, as the solenoid breaker gets activated. .Now Start the engine and warm it up to normal operating temperatures before test--driving. Perform a thorough test drive with several accelerations from a stop with light
throttle application verify the transmission shift is verified. You will have after this drive the"VSC" light "DISSAPPEAR"".
