GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
CD Changer: Help: Newbie
Old 07-10-11, 11:03 AM
GeneE
GeneE's Avatar
Default CD Changer: Help: Newbie
Trying to load the CD
I put in 6 discs I've tried them label up, label down, Compact Disc Digital Audio, and regular CD-R
I hear the changer making noise when installed.
The system won't play the CDs.
It just says "No CD"
At one point it put up a "Bluetooth connectivity problem" message
The rest of nav sys seems to work.
2005 Nav Sys Factory Changer
Any Ideas?
I've never used it and just got car.
Old 07-10-11, 11:50 AM
Bob GX
Bob GX's Avatar
Starting with the easy stuff: did you make sure the sliding door is all the way closed after you put in the CD holder? Do all of the other radio functions work ok (AM, FM, etc)? Do all the other touch screen functions work ok (heat, a/c, Nav, etc)?
I've had no trouble with my CD changer yet but other posts here say it can be an expensive repair if you end up having to take it to a dealer. An alternative could be to install an iPod interface and not use the factory changer. I added an interface from VAIS Tech - they are a vendor on this forum - top quality & works great. I dont even use the CD changer any more.
Good luck for finding a fix - hope it turns out to be something easy
Old 07-10-11, 04:23 PM
LZMF1
LZMF1's Avatar
is there a sirius or xm unit installed in your GX? i ask this because mine came with an aftermarket sirius unit and the CD changer in mine has never worked for me either. it gets power, i can hear it shuffling through the CDs when i put the magazine in but it has not and probably will not ever work for me unless i find a solution for this problem. i get the same thing.
and by the way, the proper way to load the discs is label up!
Old 07-10-11, 08:00 PM
GeneE
GeneE's Avatar
Default CD Changer
Everything seems to work on the nav system although I havent entered any addresses into Nav yet. Next step.
I dont think it had satellite radio before but not sure.
I loaded all label up again and tried making sure door is closed.
No improvement. Still won't work.
Old 07-11-11, 07:26 PM
kphu
kphu's Avatar
somethin silly but worth trying....did you try switching it to a different cd or differnt track on the cd?
Old 07-11-11, 10:03 PM
GeneE
GeneE's Avatar
Ive tried all different combinations of CD types home made to CDDA.
Old 07-13-11, 11:06 AM
kphu
kphu's Avatar
how about changing to a differnent disc on the changer? You know the cd changer can hold 6 discs, change it to another disc?
Old 07-15-11, 12:40 PM
Coffee87
Coffee87's Avatar
Are the CDs in MP3 format? Have you tried non-burned discs?
The 05 won't play MP3s and it's possible that it can't read CD-R/RW either.
Old 07-17-11, 03:48 PM
GeneE
GeneE's Avatar
Default CD changer
I've tried every combo of burned and non burned discs.
The DVD player works and plays but that will play anything.
leetheleo
11-02-16 06:51 PM
notwealthy
02-20-15 03:46 PM
KLF
01-25-15 07:38 PM
oddjob142
08-19-07 06:45 PM
mrk
12-06-04 12:35 AM
Quick Reply: CD Changer: Help: Newbie
