Source for OEM wheels?
I have a set of studded tires I would like to mount on a second set of wheels.
Any good online sources? What is the bolt pattern and backspacing of the GX wheels? What other Toyota/Lexus wheels will work on the GX, and do any look particularly good?
4Runner rims either Sport Edition 17s or Limited Edition 18s will fit and they have the same backspacing.
Also, the Toyota Tundra/Sequoia 17s will work as well. They look really good to me. You can source them on CL for about $185 bucks. If you are ****, the center cap is interchangable with Lexus.
If you decide to go aftermarket, make sure the rim is designed for the hubcentric design on the GX, 4R, and Tund/Seq. I just went with 20 inch rims and found out that I got VERY lucky. Set of rims and new tires for $500. Craigslist is your friend!!
