GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
6500lb Tow Hitch Installation and Pix
Old 08-07-14, 01:35 PM
chiph9
chiph9's Avatar
AFAIK, that comes with the factory tow-prep package. Which includes that, as well as an additional cooler in front of the radiator.
Chip H.
Old 08-09-14, 10:10 PM
koda4
koda4's Avatar
fscabrera,
2003 and early 2004 had a different center support bracket.
I think you need to purchase this one
08925-35870
see this link https://www.clublexus.com/forums/gx-...th-photos.html
koda4
Old 08-11-14, 12:15 PM
rentschl
rentschl's Avatar
Default Great Pricing on Lexus Parts!
FYI: I got the full OEM kit PT228-60540 for only $248.26 at:
http://www.oemlexusparts.com/OEMPart...T22860540.html
It's a nice source for good pricing on Lexus OEM parts in general!
-Eric
Old 02-08-15, 04:33 PM
cppaul
cppaul's Avatar
Default towing questions
So if we go with this hitch and the towing weight exceeds 5500 pounds what is everyones view of weight distribution hitch? - only for tongue weight over 550 pounds?
Old 05-29-15, 09:41 PM
burtoncr
burtoncr's Avatar
Does anyone still have the install instructions PDF? Sewell took them down.
Or if you remember the torque values for the bolts and if you used all of the shims (two sides and two centers)?
Old 09-12-16, 09:49 PM
08gx470v8
08gx470v8's Avatar
Shout out to OP for making this a breeze for me on the '08 GX470 over the weekend. Took me about 1 hour and saved a few hundred in cash. I look at this making the OEM hitch free given that there was no labor. Thanks, CL!
Old 09-12-16, 09:55 PM
08gx470v8
08gx470v8's Avatar
I just Googled the part number along with PDF and it showed up on the first page of search results from lexuspartsnow.com. Good luck!
Old 04-03-21, 06:08 AM
Tonino
Tonino's Avatar
If you're not towing much weight, you can buy a hitch attachment that will bolt on the rear of the chassis . The holes are pre-drilled and tapped and the cutoout is for a class 3 hitch; There should also be a harness with the big plug receptacle back there on the drivers side. That indicates there is a wiring harness also. You won't be able to put the little access plate back on when the hitch is installed. I leave my hitch off when I'm not towing a small boat/trailer rig (about 750lbs) and install when I need it.
Old 04-11-21, 08:18 AM
dasgroup
dasgroup's Avatar
I just picked up a used oem hitch for my 08, but missing spacer plates.. Does anyone know the thickness of those plate? I'll just use washers in their place. I have the installation instructions and list of req'd bolts, just need the spacer thickness. Not towing with it but using it for bike rack.
memphisto
06-07-14 08:26 PM
z0lt3c
18
06-23-12 10:30 PM
GGGXXX
17
04-06-06 07:52 PM
Quick Reply: 6500lb Tow Hitch Installation and Pix
