GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Cleaning MAF
Old 05-22-10, 12:05 AM
gx470_05
gx470_05's Avatar
Question Cleaning MAF
anyone know if the MAF on a 2005 is the karman vortex type?
I was thinking of cleaning the MAF with the CRC MAF Cleaner, but it states not to use it on karman vortex type MAF (some Lexus model).
Thanks in advance.
Old 05-22-10, 10:59 PM
mann777
mann777's Avatar
Yes you are right the MAF type in Lexus is equipped with Karman type Mass Air Flow Sensor, which uses a moveable mirror and transistor to measure the Air Flow wake within and the trasmittor sends signals to the ECM to adjust the air flow appropriate the idle speed required. I have heard the best is to Spray 99% pure isopropyl alcohol (available at electronic stores) onto the wires to clean and shake dry. Be careful not to use other solvents as they may damage the sensor. The MAF sensor also incorporates the intake ambient air temperature sensor so it’s a good time to also give that a quick wipe with cotton which is soaked in the above liquid air spray.
Old 05-23-10, 05:10 PM
gx470_05
gx470_05's Avatar
Thanks mann777
I'll work on this once I find some 99% pure isopropyl alcohol.
Old 05-24-10, 10:28 AM
ARK07
ARK07's Avatar
The last time I did MAF cleaning (not on my Lexus though) I put it in a plastic zip lock bag (large size) with part of bottle of Isopropyl, available at drug stores, and sloshed it back and forth for a while, drain and washed again till the fluid looked clean. Again you need air dry before re-assembling.
olsoncam
08-07-17 07:49 AM
MattJO
04-04-17 11:18 AM
The2JZFTW
Performance & Maintenance
14
02-07-13 11:30 AM
Allaretake
06-03-10 02:36 PM
95ARISTO
GS - 1st Gen (1993-1997)
12-11-06 07:17 AM
Quick Reply: Cleaning MAF
