GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
AC and Engine Revs
Old 05-20-10, 08:14 AM
MWR
MWR's Avatar
Default AC and Engine Revs
I only use AC in the summer around here, not year 'round. When I turn it on, I notice that the engine revs higher when turning the compressor, which cycles on and off. It's only a few hundred RPM, but it's quite noticeable and will make the truck surge forward when sitting at a traffic light. The dealer says this is how the AC works on a GX, so I've gotten used to it.
Has anyone else had this issue?
Old 05-20-10, 08:22 AM
Lexus 4 ME
Lexus 4 ME's Avatar
That's normal for the engine to Rev higher, because when you turn your AC your fan turns on, to cool the engine. Mine does exactly same thing.
Old 05-20-10, 09:18 AM
MWR
MWR's Avatar
That's what I thought, but it's a brutish, un-Lexus like solution to me. I have other vehicles where the AC operation is unnoticeable: an 04 Sienna, an 07 G35X, even my recently departed 08 VW EOS. Oh well.
Old 05-20-10, 10:49 AM
Lexus 4 ME
Lexus 4 ME's Avatar
May be it's due to the size of a fan blades.
Old 05-20-10, 11:28 AM
mann777
mann777's Avatar
It is absolutely normal, what exactly happen when the Engine is idle at normal stance, the signal generated by the ECU ensure constant flow of Air volume which is passing the closed throttle valves, When the AC is switch on, the ECU detects this sudden load, and adjust the Idle Speed Control based on the signals received, and increases the flow to stabilize the curb idle, when loads are applied to the engine. You will also see the following RPM increase at the following conditions, One is Electrical Load, Fast Idle,AT Load.
Old 05-20-10, 02:17 PM
Turbinator
Turbinator's Avatar
Brilliant response, thanks for the informative inputs!
Turby
Old 05-31-10, 06:32 AM
TL2008GX47
TL2008GX47's Avatar
While driving with the A/C on (doesn't matter what setting, auto, fresh, recirc, etc), does anyone notice the engine power surging when the compressor turns on/off.
For example, when cruising on the highway, I can feel the power reduced when the compressor kicks on, then about 15 seconds later when it kicks off, I can feel the power return to normal. This cycle repeats over and over again in 15-30 second intervals.
I have been to the dealership 4 times, once they replaced the condenser fan, but that did not help. I took it back for the 4th time and they said that all GX's do this and it is normal. Funny, I had a loaner RX350 and you could not feel anything with the AC running. They told me they drove a 2009 GX on the lot and it did the same thing.
It just seems odd to me that this would be normal. I drive around 50 rental cars a year and have never noticed this with the rental or on any of the other 17 cars I have owned.
I have also felt the surge while stopping, but to feel this while cruising down the highway. On/off/on/off and having to adjust the throttle to compensate does not seem "normal" to me.
Old 06-02-10, 07:35 AM
MWR
MWR's Avatar
I've had the same experieince while on the highway as well. And it doesn't seem to happen on any of the loaner cars Lexus provides, or any of the other cars I've owned, including a 2004 LS430. So we're in full agreement on this.
It just seems very un-Lexus like to me, but my dealer has told me this is normal for a GX470, so I'll have to live with it. (Maybe the engineers who developed the AC system were the same geniuses who also forgot to add a "mist" feature to the windshield wipers!)
Old 06-09-14, 08:32 AM
rockyklg
rockyklg's Avatar
bring back an old one here... any one solve this issue?
Old 06-09-14, 09:23 AM
RCsGX
RCsGX's Avatar
There's nothing to solve.
It's normal for your RPMs to shoot up a little when the A/C turns on.
Old 06-09-14, 10:04 PM
YoshiMan
YoshiMan's Avatar
Ha ha! Yeah, this thread is 4 years old, and the original poster is likely long gone, seeing that he only did 5 posts.... So I have to say, is he for real? ALL cars idle up when the A/C goes on, if anything, i would be concerned if it DIDN'T idle up...
The only car i own that doesn't do that is my 75' Cadillac, because it's got an 8.2 liter V8 and it doesn't need to idle up to compensate.
Old 06-10-14, 04:35 PM
mrblister
mrblister's Avatar
Same behavior on my 2004 GX I just deal with it
Old 06-10-14, 05:05 PM
burny
burny's Avatar
Mann ain't just another pretty face around here is he!
starkid198
07-15-16 02:02 PM
KA8
07-23-15 08:29 AM
MiiK350
06-21-12 11:38 AM
rj4510
02-19-07 06:13 PM
sayadil
07-14-06 05:46 PM
Quick Reply: AC and Engine Revs
