Rear suspension too stiff!!!
I need to get in and fiddle w/it myself. Is there a height sensor per side, or only one?
I’ve had the stiff rear shock problem with my wife’s 06 GX470. I took it to the dealer over a year ago (while it was under warranty) and they said everything was fine. Today, I took it in for services and had the same dealer check the rear shocks and was told they are “leaky” and need to be replaced. $1700 out of pocket. I’m planning to raise hell, about them telling me all was good and now that the car is off of warranty, there’s a problem…
Today I finally got under the rear of the truck and fiddled w/the height sensors. In simple terms, you take a 12mm wrench, loosen the nut on the lower-end of the arm, and slide the nut *down* in the adjustment slot (to lower).
At first, I slid it all the way down to see what would happen. It lowered the truck way down. Too far, to the point where it couldn't get into "low" mode because it was on the bump stops.
I got back under and slid it to the point where you could just barely see the slot peek out from next to the nut.
Result: lowered the truck 1" in the rear, and it rides much much better.
Update: My truck had been riding roughly (in the rear) ever since the clunk TSB work was done. It was also riding much higher in the rear.
Good to hear that you fixed this. DId you do it the same way on both sides? Noticed that mine were at different slot heights (the left being higher than the right side) but the truck is level. Can you tell us how the ride is better?
I forgot whether you were trying to raise or lower, but you might try evening them "up" or "down"to see what happens. Also try measuring hte lengths of your two rods. Mine were equal at just a hair over 4".
The rear of mine was jacked way up after the dealer did the clunk job. The smoother ride makes sense to me simply because the airbags aren't inflated nearly as much @ the current height. What I attempted to do was lower it to the point where it felt like I was *just* staying off of the "bump stops" in normal driving.
When I'm in "L", I can just fit my pinkie between the bumpstop and the axle.
FWIW, I have 18" 4runner rims, and went from 12" to 11" from the rim "bead" to the edge of the wheel-well.
Drives great, and the headlights are now aimed right again. I may tweak it slightly higher if I find I'm on the bumpstops more than I'd like.
