How to Change Front & Rear Differential Gear oil on GX ( Tutorial )
Old 02-16-10, 07:50 AM
mann777
mann777's Avatar
Lightbulb How to Change Front & Rear Differential Gear oil on GX ( Tutorial )
Last week I did the Differential oil, I happen to compile it so that it becomes a easy one for members to do this at home. Quite Simple and you can save the dollars. All you need basic tools. These are effective for 2003 Onwards to 2009 GX Models Cheers
Correction to the Attachement P/N for Rear Drain Plug & * Gasket
1.90341-18057 - 1Qty
2.* 12157-10010
The following 4 users liked this post by mann777:
Arailt (03-13-18), Sam7768 (08-28-24), simb (05-26-19), vangx470 (04-10-17)
Old 02-16-10, 09:10 AM
mansito
mansito's Avatar
mann777,
How many miles on your GX470? If this is not the first time you change the diff oil, how often do you change it.
Thanks,
Old 02-16-10, 09:20 AM
mann777
mann777's Avatar
I changed at 75K. This is the first time, I have changed it, The dealer till the warranty expired was only doing an inspection and top up. I decided to have the complete oil replaced.
Old 02-16-10, 11:44 AM
SIERRAGX
SIERRAGX's Avatar
Thanks Mann, just the info I am looking for as my 04 is reaching 65k miles, I have been thinking changing it.
It is it necessary to change the plugs?, I know the gaskets should be.
Thanks.
Old 02-16-10, 02:23 PM
Lexmex
Super Moderator
Lexmex's Avatar
Very well done. I'll have to remember this as the mrs. may want a GX470 when we get rid of her Expedition.
Old 02-16-10, 02:37 PM
mansito
mansito's Avatar
Mann,
Thank you. Only 54K on my wife's GX470. Still a couple of years to go. Very nice description of the whole process.
Old 02-16-10, 02:57 PM
jditom
jditom's Avatar
Nice write up
I did mine at 65k and I also did the transfer case since it is the same procedure as the diffs and same fluid.
Jwr3265 (06-10-22)
Old 02-16-10, 07:05 PM
lexwoody
lexwoody's Avatar
Here is another write up.
http://www.toyota120.com/forum/showthread.php?t=3369
Old 02-16-10, 07:21 PM
mann777
mann777's Avatar
Thanks.
The reason I went was prior to the change the dealer long back had done the oil top up, could be an apprentice done the change, but I observed was the all the Plugs had a bit of damage, I suppose the Hex 10mm was not seated properly in the slot, there was bit of metal shavings out, I had to ensure to get this job done have it replace, cost just a few bucks. Only One thing you should ensure the first time to remove, you have to give a few shots with a Fibre mallet on the plugs to make the grip bit loosen, then it all becomes a peice of cake.
Old 02-17-10, 01:52 AM
SIERRAGX
SIERRAGX's Avatar
Thank you so much Mann.
Do you happen to know the Toyota part # for the transfer case gasket?
Andrew
Old 02-17-10, 07:39 AM
mann777
mann777's Avatar
The part number is 35168-60010. Here is the image, as I just recently ordered from sewell.
Attached Thumbnails How to Change Front & Rear Differential Gear oil on GX ( Tutorial )-transmision-pan-gasket.jpg
Old 02-17-10, 08:45 AM
SIERRAGX
SIERRAGX's Avatar
Thanks again Mann,your the man.
Old 03-03-10, 08:29 AM
Vinniety
Vinniety's Avatar
Originally Posted by lexwoody
Lexwoody - in that link you posted witht he thread on changing fluids and greasing the ujoints can you explain a little bit more on why they use different greas for different parts of the driveshaft.
The blue zerk is for the slipjoint (apply moly grease to it) and the green the U-joint (normal Lithium grease). There is 3 zerks on each drive shaft (front and rear) (one slipjoint by transfer case side and 2 U-joints). On the U-joint keep pumping grease till you can see the new grease coming out of the u_joint then wipe clean all the excess grease. This is why I like the pink Mobil 1 grease as it is easy to spot.
Old 03-03-10, 08:47 AM
mann777
mann777's Avatar
Sorry to dive in !!!
Check out the Owner Manual
— CHASSIS LUBRICATION
Propeller shafts
Spiders - - Lithium base chassis grease, NLGI No.2
Slide yoke - Molybdenum-disulfide lithium base chassis grease.
Attached Thumbnails How to Change Front & Rear Differential Gear oil on GX ( Tutorial )-propeller-shaft-assembly-03.jpg
drkatnaga (08-27-20)
Old 03-03-10, 09:00 AM
Vinniety
Vinniety's Avatar
ALLSOME mann777!!! thanks so much for the quick reply!!!
Quick Reply: How to Change Front & Rear Differential Gear oil on GX ( Tutorial )
