Go Back   Club Lexus Forums > Lexus Model Forums > GX Models > GX - First Generation
Sign in using an external account
Register Forgot Password?
How to Change Front & Rear Differential Gear oil on GX ( Tutorial )
Thread Tools Search this Thread Display Modes
Old 06-05-12, 11:56 AM   #46
hammer0008
Trader Score: (0)
hammer0008's Avatar
Quote:
Originally Posted by mann777 View Post
I suggest you use a Hex Impact Sockets, with Impact Bar wrenches as they would be better. As the area is limited to work, it would be the best shot or if could borrow power tools on a loaner basis from pepboys. That would be the best bet ! Dont make it worse by slipping it more, then the grips become limited.
I think I may have made it worse. There is lots of free play now with the 10mm hex....about 20 degrees free play which I think means it has been stripped.
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
__________________
ham
gx470 2007 Cypress pearl Led stop + int, hid6000
hammer0008 is offline   Reply With Quote
Old 06-05-12, 05:20 PM   #47
Taco_Kid
Trader Score: (0)
Quote:
Originally Posted by hammer0008 View Post
Just did the the rear and transfer case. No problem. The rear was really dirty at 55k. Transfer case was clean.
However the front diff is giving me problems. I can not get the drain plug off.
1. hammered with a plastic hammer
2. pb blaster
3. 1/2 breaker bar and 3 feet copper pipe
that hex nut won't budge!!!
any luck? i sometime try heat, propane plumbing torch, nothing more. heat the bolt but not cherry red (i dont think you could anyways with oil in there, just too much heat sink going on). heat it good, whack it a few times with ball-peen hammer, then try to loosen it.
last resort is to drill a pilot hole and use proper extractor. if that fails you need to drill the hole as big as possible then small chisel to collapse what's left all while trying to save threads on the case.
and for me, i use the Valvoline gear oils.
Taco_Kid is offline   Reply With Quote
Old 06-05-12, 09:00 PM   #48
mann777
Trader Score: (0)
mann777's Avatar
Ok I think now that the grips for the hex are loose, As taco Suggest "Chisel it out". Anyway before you try this spray some WD40 around and wait for a while and start this job.
__________________
LS400-1994/GX470-2004(KDSS) (HIS)
Ability is what you're capable of doing...
Motivation determines what you do...
Attitude determines how well you do it.
mann777 is offline   Reply With Quote
Old 11-21-13, 05:45 PM   #49
RCsGX
Trader Score: (0)
RCsGX's Avatar
2. pb blaster
Hammer0008 did you ever get it out? I'm surprised the PB blaster or breaker bar didn't help.
I changed my rear diff and transfer case about a month or so ago and I used my Milwaukee 3/8" impact (200ftlb.). It had no problem w/ the bolts, it hammered 1-2 times before zipping them right off. I just changed my front diff oil earlier this week and the drain bolt was on there tight, it wouldn't even budge w/ the impact. I ended up using a 2ft 1/2" breaker and literally stood on it to break it loose.
__________________
▲ click the pic to view my mods ▲
- Lifted 2.5" Front Icon Coilovers w/ CDC Valve ❚ Rear Bilstein 5100s
18" BFD Wheels ❚ 285/60/18 Nitto Terra Grapplers
HID Retro *SC430 Projectors* ❚ Interior & Exterior LEDs
VaisTech ❚ Coastal Lockpick
Sport Taillights
5% Llumar CTX Tint All Around
RCsGX is offline   Reply With Quote
Old 01-10-14, 07:33 AM   #50
IanB2
Trader Score: (0)
IanB2's Avatar
Got this knocked off my list last night, thanks for the DIY!
__________________
'04 GX470 - ML audio w/ RSES, 4300k HID, GROM USB2 w/BT, FJ Cruiser 6-spokes w/ Lexus centercaps, 265/70/17C Duratracs, TPMS disabled, weathertech mats & cargo mat
'93 Land Cruiser HDJ81 - 3X diff locks, winch, center console fridge, 285/75/16E Duratracs, 2.5" lift w/ Fox IFP V2.0, HID retrofit, IPF SuperRally aux lights, Aussie front bumper
'99 MB E55t AMG - 354hp/390ft/lb torque Daily Driver
IanB2 is offline   Reply With Quote
Old 02-24-14, 09:04 AM   #51
shkGX470
Trader Score: (0)
Are you guys finding it essential to change out the drain/fill plugs and washers or just the crush washers? I'm definitely going to changing out the differential fluids with Mobil 1 synthetic (75w90) but didn't know if it was essential to change out the drain/fill plugs as well. My intention was just to replace the washers but looking at this DIY got me thinking.
shkGX470 is offline   Reply With Quote
Old 02-24-14, 12:03 PM   #52
Booyah
Trader Score: (0)
Booyah's Avatar
Quote:
Just the crush washers I would replace! No need to replace the bolt unless its mangled up...
__________________
2008 GX-470 BLIZZARD PEARL | 5K HID'S FOGS/LOW BEAMS
2008 BMW 335XI -Wifes Ride | White
www.xenondepot.com
Booyah is offline   Reply With Quote
Old 02-25-14, 06:25 AM   #53
shkGX470
Trader Score: (0)
Quote:
That's kinda what I figured but just wanted to check. Thanks so much!
Old 03-28-14, 09:31 AM   #54
amccaulx
Trader Score: (0)
My Front Diff's had a leak ever since I got it. I figured the PO just didn't replace the crush washer, so I drained/filled and replaced crush washer, but it still leaked. Then as a last resort, I decided to get a new Drain Plug, and did another Drain/Fill with the new plug, and no more leak!
You should replace the washers each time, and why wouldn't you, it is so cheap. I think it is a good idea to replace the plugs as well every few times atleast. as they are pretty cheap as well, and with so many people having issues with the stripped front ones, that would help. If you have never changed them out before, it woldn't be a bad idea to.
amccaulx is offline   Reply With Quote
Old 04-27-14, 06:59 PM   #55
Sethro
Trader Score: (0)
Adventure Driven
Great write up, just serviced mine. My front diff drain plug was really over tight too.
Seth
Sethro is offline   Reply With Quote
Old 06-18-14, 08:05 PM   #56
JoshBunch
Trader Score: (0)
To the OP, thanks for the write up. This is almost identical to my 2000 4Runner.
That being said, I did the same thing as hammer with the front differential. I cannot state this enough, always remove the fill plug first. Always. I didn't find this out the hard way but a buddy did. His fill plug got stuck and well, it was a bad situation.
When changing the differential oil on my 4runner the front differential drain plug gave me fits as well. I do not know why they put a Hex fitting in this one and normal socket plugs on the others, it's infuriating. What happened was I had a ton of 'junk' (oil, dirt, road debris) crammed in the back of the hex fitting I didn't know was there, so when I stuck the 10mm hex wrench in there, I thought I was all the way in but in reality I was only 1/2 way in, so I stripped the top half out. Once I realized that, I sprayed cleaner in the hole and saw what had happened. It was too late, the back half of the plug wouldn't grab the hex wrench and eventually stripped some too. I tried heat, didn't work, over 1/2 a can of PB Blaster, I welded several sockets to the plug, nothing...finally I decided to weld the 10mm hex wrench in the hole(making sure I could get 1/2 a turn in). Once welded in place, i was able to get 1/2 a turn out of it, then had to cut off the long arm with a grinder, and backed the thing out with relative ease.
The moral of the story is make sure both the hex plugs for the front differential and cleaned out and you can get your hex wrench all the way in there to be able to grab it all the way.
I never saw Hammer respond if he got the thing resolved but I wanted to post this I case anyone else ran into this issue. I'll be changing the differential and transfer case fluids in our newly acquired GX soon and I will be sure not to make the same mistake twice.
JoshBunch is offline   Reply With Quote
Old 07-11-14, 03:57 PM   #57
MichaelD86
Trader Score: (0)
MichaelD86's Avatar
I just did it. Although mylexus didnt show any record of the diffs and transfer case fluid being changed someone has done it before. I know that because the use of a torque wrench was not utilized. I was hanging all my body weight with a breaker bar underneath the car to get them to break loose. The front diff took heat to get it broken loose. The fluid didnt look too bad but im glad I did it anyway. Did all synthetic and have some peace of mind.
MichaelD86 is offline   Reply With Quote
Old 08-25-14, 06:34 AM   #58
shkGX470
Trader Score: (0)
Quick question: is the transfer case filler plug and drain plug the same as the rear differential filler plug, meaning part number 90341-18006? Thanks!
Old 08-25-14, 07:10 AM   #59
chiph9
Trader Score: (0)
It appears to be. p/n 36114B
http://lexus.sewellparts.com/oem-cat...X470-2004.html
__________________
chiph9 is offline   Reply With Quote
Old 08-25-14, 11:50 AM   #60
shkGX470
Trader Score: (0)
Thanks! I'll buy three!
Similar Threads
Thread Thread Starter Forum Replies Last Post
JasonChang 2ISGFM Build Thread JasonChang Build Threads 80 11-11-13 09:17 PM
WA IS3_FTW FS thread *pics 5/27/12* post #2 IS3_FTW 1Gen IS300 Classifieds (98-05) 13 05-25-13 05:02 PM
CA FS: 1jz stock turbos, EBC brake pads OneJay SC400 / 300 Classifieds 3 12-04-12 08:38 AM
TN FS, Even more parts Cleaned Up From Last Sale sakataj 2Gen GS430 / 400/ 300 Classifieds (98-05) 60 07-01-11 02:11 PM
FL FS: Wilwood BBK, BCR Coils, Vossen CV1, Falken JMcDonald 2Gen IS250 / IS350 / IS-F Classifieds (06-13) 13 05-28-11 08:40 PM
Tags
470, cruiser, diff, differential, differentials, es250, front, gear, gx, land, lexus, metal, mt, oil, rear, replace, rx330, shavings
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Copyright © 2000-2015 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
