90000 service
Here is the Service chart for 90K
Replace engine oil and oil filter; reset reminder light
❏ Rotate tires
❏ Clean air conditioner filter (RX)
❏ Lubricate drive shaft, re-torque nuts and bolts (GX, LX)
❏ Visually inspect brake pads and rotors
❏ Road-test vehicle
❏ Inspect the following:
___Active height control system (LX)
___Axle shaft boots
___Ball joints and dust covers
___Body
___Brake lines and hoses
___Drive belt
___Engine coolant (see page 68)
Additional Maintenance Required If You Drive Primarily Under the Following Conditions
Driving off-road, on dirt roads or on dusty roads:
❏ Inspect engine air filter
❏ Tighten nuts and bolts on chassis
Driving while towing:
❏ Replace front differential oil (GX, LX)
❏ Replace rear differential oil (AWD/4WD only)
❏ Replace transfer case oil (RX AWD only)
___Exhaust pipes and mountings
___Front differential oil (GX, LX)
___Rack and pinion assembly
___Rear differential oil (AWD/4WD only)
___Steering linkage and boots
___Transfer case oil (RX AWD only).
But regardless of the condition
The following is changed for me. 8Plugs/Timing Belt / Water Pump, All Engine/Trans oils & Filters replaced. My Front Wheel Axle Boot was replaced. Had the Wheels Balanced ( was bit off) All for 2750/- 1 year back, with a cheap smile , and the freebies ( coffee/ Warped 18th Century Donuts).
❏ Rotate tires
❏ Road-test vehicle
___Axle shaft boots
___Body
___Drive belt
I also do my own wrenching, but when time comes, I am planning to leave the timing belt job to the dealer or my local (trusted) indie mechanic.
Matsui
GX - 1st Gen (2003-2009)
28
02-11-22 02:27 PM
