GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Check Engine, VSC Trac, VSC Off, Anti Skid Lights On
Old 09-20-16, 10:49 AM
bclare13
bclare13's Avatar
Default Check Engine, VSC Trac, VSC Off, Anti Skid Lights On
The codes that were pulled were P0031, P0038, and P0036. It was suggested to me that I needed to get the O2 sensor(s) replaced. I haven't done that yet but I wanted to get second opinions. The car has about 70k miles and I've only owned it about 2 months now. The maintenance light is also on because I need to get the oil changed and tires rotated. Could the maintenance light have anything to do with the other check engine lights coming on or do you think this is something I need to get fixed?
Old 09-20-16, 11:58 AM
chiph9
chiph9's Avatar
Before spending a ton of money, replace the gas cap. This series of lights is common when there's an air leak in the gas tank (evaporative emissions failure).
Chip H.
Old 09-20-16, 12:00 PM
bclare13
bclare13's Avatar
Chip H.
Thanks i'll try it. Is there anyway to check to see if your gas cap is leaking air before replacing? Or do you just need to replace it and then drive it a while and hope it fixes the issue?
Old 09-20-16, 12:53 PM
erkelbot
erkelbot's Avatar
99% sure it's the fuel cap. Toyota is nuts about engine management when there are even small issues/warnings. So if the vacuum for the cap is failing (which has been well documented all over the webs), the truck will disable all of the nannies to ensure no engine damage occurs. Spend $20-$30 and get the OEM part. That may make your headache go away very easily...
Old 09-20-16, 12:55 PM
erkelbot
erkelbot's Avatar
Step 1: Take off the old part and put on the new one. Step 2: Drive away smiling with all lights turned off. I don't think there's anything special needed -- other than the new part.
Old 09-20-16, 01:20 PM
Looks like O2 sensor. I believe this will be multiple sensors that need to be replaced...Sorry to hear. 70K is not a lot of miles for the 4.7
Old 09-20-16, 01:37 PM
chiph9
chiph9's Avatar
If your vehicle is 10+ years old(-ish), that's about when the gasket on it wears out.
You may still need a new O2 sensor, but this ought to clear up a lot of those lights.
Chip H.
Old 09-20-16, 03:45 PM
bclare13
bclare13's Avatar
Chip H.
Update for anyone interested:
I have the 2008 GX470 if anyone was curious. Anyways I went ahead and got a new gas cap from a Lexus dealership. I went to an autozone and they erased my codes for me. However, the check engine and all the other lights came on about 2 or 3 minutes after the car was started. Looks like you guys are right it is the oxygen sensor. I'm taking it in tomorrow to get it replaced.
gshort
02-15-19 07:00 PM
foreste1
02-19-17 01:14 PM
LXBriGuy
05-19-16 03:11 PM
URDONE
09-01-11 04:30 AM
kalali
RX - 1st Gen (1999-2003)
13
10-30-10 02:29 PM
Quick Reply: Check Engine, VSC Trac, VSC Off, Anti Skid Lights On
