Rim Fitment Question from Sequoa to GX?
my bro in law has a Bazo 22 x 9.5 inch rims on his 05 Sequoa. Could i use the same rims on my car? He is running 265/45/22 (i think) which is YUCKY..... he couldnt go wider or because of the front shock strut was getting in the way. As far as offset on those rims.. hmm could be in the mid 20s... 24?? 23mm.. forget...
Does Sequoa have similar clearnace issue as our GX470 does??? only way to find out is to just try it on i guess.... as far as balancing issue or what not.... i dont think i need to right?? unless im changing tires size.. which i want to to 305/40/22... hope that fits...
GX stock offset is +20mm and Sequoia have a +15mm which will work. 305/40/22 is about an inch to big. On the GX the front will rub the front fender well when you make a sharp turn. Other than that it shouldn't be any problem. As for wheel balance, make sure they force balance it or it will vibrate at 55 to 65mph.
http://www.ronalusa.com/cars/toyota_tundra.html
http://www.ronalusa.com/cars/lexus_gx470.html
http://www.1010tires.com/TireSizeCal...?action=submit
http://www.gsp9700.com/pub/technical/4127T/4127t.cfm
Cwiok71
GX - 1st Gen (2004-2009)
05-23-19 01:33 PM
