GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
22's on GX
Old 01-26-06, 09:52 PM
kidlt
kidlt's Avatar
Default 22's on GX
How do 22's ride on GX?
Old 01-27-06, 04:45 AM
JWS3
JWS3's Avatar
Default No personal expereince, but try the Tirerack
They are generally a decent source. Give them a call.
Old 01-27-06, 08:55 PM
peterGX470
peterGX470's Avatar
Ride and handle much better than stock
Old 01-28-06, 07:37 AM
The G Man
The G Man's Avatar
Lower profile tires usually handles better but the trade off is that you will feel every bump.
Old 01-28-06, 09:19 AM
BobsGX
BobsGX's Avatar
That's for sure. I like the GX just fine with the 17" wheels. Even going to 18" wheels will give a rougher ride. No thanks.
Old 01-28-06, 02:51 PM
angelslex
angelslex's Avatar
Go with 22"
Old 01-28-06, 04:47 PM
ias
ias's Avatar
Originally Posted by angelslex
Go with 22"
22's were sooo year before last...24s were sooo last year...get some 26s
Old 01-29-06, 11:50 AM
Kash
Kash's Avatar
pics of the 26's you want to get...
Old 01-31-06, 09:27 AM
ias
ias's Avatar
http://www.chipfoose.com/speedster6.aspx
Old 01-31-06, 06:11 PM
peterGX470
peterGX470's Avatar
What size tire will you be using with the 26" ??
Old 01-31-06, 08:07 PM
lonewolf69
lonewolf69's Avatar
Hmmm, hello Local Lexus Dealer, I just installed 26" wheels onto my GX and now I can only go in a straight line because I can't turn the steering without the tires rubbing the wheel well!
JK!
Will the 26" wheels really fIt the GX and if SO, I would LOVE to see pictures!!!
-Alex
Old 01-31-06, 08:29 PM
ias
ias's Avatar
The 24s fit just about perfect..I had to trim about an inch off the inside of the mudflap and now there are no rubbing issues what so ever. The 26s are only .1 inch taller and .25inches wider than the 24s with the smaller sidewall.
Old 01-31-06, 08:32 PM
ias
ias's Avatar
someone please buy my 24s
Old 02-01-06, 10:28 AM
batmobl
batmobl's Avatar
how much are you selling them for (including shipping to NC)?
Old 02-01-06, 02:43 PM
peterGX470
peterGX470's Avatar
Default Very Confused...
The Stock over all diameter is 30.56" (265/65/17) http://www.1010tires.com/TireSizeCal...?action=submit
With 26" wheel consider the tire size option is 305/35/26 your over all diameter is 34.4" which is about 4" bigger! You are over 11% !
With 305/30/26 which is 33.2", a 8% bigger! There no other size in between on the market unless you can get it special made in 295/20/26 which is 30.65" which i doubt it!
If your GX wheel are not +/- 3% you are in danger of brake failure!! Not to mention your speedometer is off, way off!!
So! My question is HOW do you put 26" on your GX and only gain .1" or 1" overall diameter????
Maybe with out the tire...j/k
Let see some pictures??
Quick Reply: 22's on GX
