Disable Tire Pressure Sensors?
Old 11-05-08, 09:39 AM
jditom
jditom's Avatar
Or you can buy my sensors cheep for an extra set of wheels.
The GX is set up with a switch for 2 sets of wheels with TMPS. Once programed in for both sets you never go back to the dealer
http://eugene.craigslist.org/pts/893977583.html
Old 11-05-08, 10:11 AM
The G Man
The G Man's Avatar
Now, how do we diable the airbags, when I was growing up, real men dont need airbags in cars
Old 11-05-08, 10:19 AM
DUKE34
DUKE34's Avatar
Just so you know the sensor also monitors the spare tire as well.
Old 11-05-08, 10:26 AM
Lac
Lac's Avatar
The problem is that my TPMS doesn't work properly. Lexus dealer replaced the sensors a few times.
Old 09-30-13, 11:22 AM
eburggx470
eburggx470's Avatar
Thank you all for this tip/fix. But I must be a little thick in the head. The instructions on which end of the wire to ground were not that clear to me. However, after trial and error, I found the correct one. Once you cut the blue wire, leave the end hanging out of the plug alone. The other half of the wire, the half that continues up underneath the dash, is the end you want to ground. There is some sort of box mounted underneath the dash on the right side wall that has a metal plate cover. I grounded the wire to a screw holding that plate cover. Whatever you use you should check with a test light to make sure it's a good ground. Not all the metal parts under there will work.
17Jarrel (09-05-20)
Old 10-28-13, 10:46 AM
skifanatic
skifanatic's Avatar
I am going to follow the instructions from another forum.
http://www.toyota-4runner.org/4th-ge...-switch-4.html
This fellow installed a switch so you can turn off the TPMS system when running wheels without the sensors.
The only difference is the colour of the wire, the connector# is 6 for the 4runner and the GX.
Will post the results.
Old 12-14-13, 09:34 AM
deanbaiju
deanbaiju's Avatar
Default Rx350 and gs300
I have two problems.
Firstly, the engine light on the rx350 (2006, English RHD) came on with the vsc light. I was told it was the bank1 sensor1 and bank2 sensor2. Does anyone know where these are, what are the denso part codes for all four bank sensors and is there a picture or schematic I can follow to change them.
Secondly, I have a problem with the tpms of my gs300 (2006, English RHD). A dashboard light came on, the display said check system, and the triangular warning light came on. I had it checked and was told to replace a sensor. All lights went off, but it came back three days later. I then changes all the sensors which again lasted only three days. I was wondering if I disconnected the tpms light would it take came of all three lights / displays. Or what should I do.
Old 12-14-13, 09:46 AM
eburggx470
eburggx470's Avatar
Bank 1, Sensor 1 is probably referring to an oxygen sensor in the exhaust pipe coming off the manifold, not a tire sensor. There are 4 oxygen sensors on my GX470. 2 on the left, 2 on the right. You'll have Bank 1, Sensor 1 and 2. The other side will be Bank 2 Sensor 1 and 2. Check elsewhere in this forum for more.
Old 03-24-14, 11:02 AM
470reasons
470reasons's Avatar
Followed angelslex and eburggx470's instructions.
HINTS:
Don't cut the wire right at the connector. Someone may want to reconnect and use the TMPS feature later on.
If a ratchet style crimp tool is not used, solder the crimped lug in addition to crimping.
This is my GX with the mod ready to connect to the ground screw.
MotoTundra (12-18-19)
Old 04-26-14, 02:17 PM
GreggyG
GreggyG's Avatar
worked like a charm, thank you!
Old 09-27-14, 11:33 AM
DirtyGX
DirtyGX's Avatar
I just did this, my TPMS light went from blinking to steadily lit. Was I supposed to disconnect the battery?
I grounded the blue wire to a post behind the kick panel.
Old 09-28-14, 07:14 AM
DirtyGX
DirtyGX's Avatar
Never mind guys, I grounded the plug end. Reading the entire thread I saw someone else had the same issue. Moved the ground to the correct side.
Old 12-07-14, 07:48 AM
ArXane
ArXane's Avatar
Originally Posted by angelslex
If you doing aftermarket wheels you ither have to buy new sensor or take the sensor from you OEM wheels and tires and put them into the new wheels and tires so the light won't stay on and the prices for each new sensor are $100 a piece and then you have to take them to get it program. Is to much of a headache so i came up with a simple solution i grow up driving older car with none of this new pain in the a** sensor BYPASS I know when i need air in my tires i don't need an ECU unit telling me this. all you need to do is cut one wire and ground it .
Thank you for this write up. Worked perfect.
Old 06-24-15, 04:41 PM
tightlinez
tightlinez's Avatar
So i tried grounding the blue wire coming out of the TPMS box and it doesn't work. Any further info on the is much appreciated.
Old 06-25-15, 05:24 AM
NTH
NTH's Avatar
This didn't work for my '07 either. I've tried both ends of the cut blue wire but light still flashing then steady.
Quick Reply: Disable Tire Pressure Sensors?
