Go Back   Club Lexus Forums > Lexus Model Forums > GX 470 Model
Thread Tools Display Modes
Old 07-27-08, 12:03 PM   #16
kokohead
Trader Score: (0)
kokohead's Avatar
Thumbs up 27F Interstate Battery
Sam's Club has the 27F INTERSTATE battery for $80, this is the exact Lexus branded battery with 84 months warranty for $130 + $40 installation.
kokohead is offline   Reply With Quote
Old 07-28-08, 05:08 PM   #17
itsZep
2009 Lexus GX
My Garage
Trader Score: (0)
itsZep's Avatar
I was a bit surprised when I took my 2004 GX in recently for a pre-vacation check-up and they said my battery was not in good shape. I asked how much it would be to replace it and they said "oh thats under warranty...it won't cost a thing". It's hard to beat that price and I do not have an extended warranty.
__________________
2009 - GX 470 - Nautical Blue Metallic
itsZep is offline   Reply With Quote
Old 07-28-08, 05:34 PM   #18
BurgBoxstr
Trader Score: (0)
Quote:
Originally Posted by Capirato View Post
The 24F is the replacement size for the truck, NOT the 27F.
The 24F was listed at all the four places I went looking for a battery for the GX.
~ Cap
24F will work...... but it's only applicable in WARM climates
27F is applicable for both warm or cold
Did Lexus really put in 2 types of batteries?
Even if one came w/ a 24F, replacing w/ a 27F will not hurt one tiny bit - probably would be better. Based on CCAs, no sense cutting short what you might need someday as Murphy's Law shall prevail..... My OEM Panasonic battery was definitely 27F series. I'd recommend people replace w/ what [size] came stock.
Incidentally, I'm surprised a 24F fit w/out cable extension(s). That was not my experience when I replaced w/ an Optima 34R (which is the same size IIRC). Details?
BurgBoxstr is offline   Reply With Quote
Old 07-28-08, 07:26 PM   #19
BurgBoxstr
Trader Score: (0)
The 24F is 11 inches long and the 27F is 12 1/2 inches long.
Yes 27F is longer than 24F.
According to every parts store and battery website I went to, The OE group size for the Lexus GX470 is 27F. Sears, yeah the sharpest knife in the retail (and automotive) drawer , says 24F is ok...... in warm climates but recommends the 27F. Are they all wrong?
I didn't replace w/ a 27F in (b/c I chose Optima) but IIRC my OEM battery was 12 7/8" or very close and I'm sure the tray could handle it (I'll measure tomorrow).
You didn't answer my question.....
Did your 24F fit w/out cable extensions?
My Optima 34R required a 2" extension on the ground and it measures in at 10" (my issue was how far in the posts are mounted on optima R so may not have been an issue w/ you?).
The other problem people may run into is a lot of 24F batteries have less CCAs than 27F. I think the lowest 27F I saw was 650 CCA's while I've seen some 24F ~ 500CCAs. In a warmer climates, not an issue, but where it's cool let alone cold.... 24F could certainly leave you SOL....
Old 09-08-08, 09:14 AM   #20
cmarshack
Trader Score: (0)
Sorry I didn't answer, because the question didn't make sense to me.
The 24F is an exact replica of the OEM battery, therefore the cables fit perfectly on the 24F replacement battery.
~ Cap
I just bought the OEM replacement from Lexus on Saturday and it's definately a 27F. Cost $110 bucks and was exactly the same size as the Panasonic that I pulled out. I wonder why yours is a 24F? Maybe they did put two different battaries in these trucks.
__________________
22" Boss 313 Black Chrome
305-40-22 Hankook Ventus RH-06
6000K XD Xenon
Prado LED Tail Lights
Drilled & Slotted Rotors w/GreenStuff Ultimate
Custom Magnaflow Cat-Back Dual Exhaust
cmarshack is offline   Reply With Quote
Old 10-12-09, 09:58 PM   #21
ERC4
Trader Score: (0)
Quote:
Chad,
What's the brand and model of battery that you got from Lexus? Was the $110 installed or just for the battery alone?
Thanks,
Gene
ERC4 is offline   Reply With Quote
Tags
2003, 24f, 27f, batteries, battery, car, group, gx470, interstate, lexus, location, lx470, replace, replacement, size
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Go
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
