Navi Update to V15A8910 skip the dealer
Old 03-19-17, 05:23 AM
sarcoptic
sarcoptic's Avatar
Default Navi Update to V15A8910 skip the dealer
For those technically incline and want to skip the dealer, I found the latest update to our navigation units online. The latest version is V15A8910 based on the TSB here:
http://www.revbase.com/BBBMotor/TSb/...dPdf?id=197088
The firmware itself can be grabbed straight from Lexus here:
https://dl.securedp.toyota.com/lexus/entune/13LHENNA-AA01_0004.kwi
Quick steps:
1. Download the above file. Take a USB key and format the key as FAT32, MUST BE FAT32!!!
2. Plug the key into the car, start the car (as in leave the car running)
3. Go to General Settings then down to Software Update, finally Update (NOT Gracenote update)
4. The screen will show you your current version and give you the option to proceed with an update if one is needed, if one is not the update button will not be enabled
5. Update takes around 5 minutes or so, leave the USB key plugged in and follow all the instructions.
6. Enjoy skipping the dealer for updates
This firmware update applies to the GX. Just verify your firmware version is following the similar scheme as V15AXXXX
sarcoptic is offline
Old 03-19-17, 01:54 PM
Statman
Statman's Avatar
So the link to the firmware is not correct for the GX...the current version that downloads from the Lexus site is: 13LHENNA-AA01_1021.kwi
Statman is offline
Old 03-19-17, 07:39 PM
clickart
clickart's Avatar
Anybody know where I can download the latest firmware for the GX?
clickart is offline
Old 03-19-17, 09:25 PM
Statman
Statman's Avatar
HERE
Statman is offline
Old 03-20-17, 04:44 AM
sarcoptic
sarcoptic's Avatar
Trust me my link is correct. Following LexusDrivers points to an older version. I know the filenames seem funky but my link will get you 8910 (the latest)...8872 is not the latest (LexusDrivers link).
Old 03-20-17, 07:33 AM
ELEX470
ELEX470's Avatar
Can One update NAVI for GX460 2011 using this method?
If yes where is the USB port located for updating NAVI to the latest version?
If not anyone knows how i can update 2011 GX460 without going to the dealer?
ELEX470 is offline
Old 03-20-17, 08:44 AM
Statman
Statman's Avatar
Well I used your link, downloaded file and the car would not let that file load...not sure why, but when I downloaded the other file it did update. I realize it seems down level, but don't know how to get the correct file other than through the lexus portal. Your link gives me a file named:
13LHENNA-AB01_0003.kwi
No, you can not update Navi maps via this method AFAIK.
Statman is offline
Old 03-20-17, 01:56 PM
GoHuskers
GoHuskers's Avatar
Quick steps:
OP,
Your link shows the file for download is ***0004.kwi but when you click on it the actual file to download is ***0003.kwi.
Why is the different? Thanks.
GoHuskers is offline
Old 03-20-17, 03:44 PM
MickeyS
MickeyS's Avatar
It only says GX460 2015-2016 this is not good if you have a 2010 would it be?
MickeyS is offline
Old 03-20-17, 04:20 PM
bd5400
bd5400's Avatar
Updates are not cross compatible between infotainment generations. This would not apply to the 2010-2013 models.
bd5400 is offline
Old 03-20-17, 04:50 PM
ELEX470
ELEX470's Avatar
In other words bd5400
Can we or cannot update with USB 2010 -2013 models?
are you talking about NAV generations ?
not clears please clarify.
ELEX470 is offline
Old 03-20-17, 04:57 PM
bd5400
bd5400's Avatar
Lexus lists the 2010-2013 GX models as dealer only USB updates. Whether there is a workaround I do not know as I have not come across anyone who has done it successfully.
bd5400 is offline
Old 03-21-17, 01:36 AM
sarcoptic
sarcoptic's Avatar
Yeah sorry this is for the newer models. That is why I mentioned to check your current version and make sure it follows the same naming scheme of V15AXXXX.
Old 03-22-17, 04:49 PM
ducttape
ducttape's Avatar
Listed below is the TSB for 2010-2013 models:
http://www.revbase.com/BBBMotor/TSb/...dPdf?id=192035
ducttape is offline
Old 03-22-17, 04:52 PM
ducttape
ducttape's Avatar
And here the one for 2014 to cover all models:
http://www.revbase.com/BBBMotor/TSb/...dPdf?id=197086
ducttape is offline
Quick Reply: Navi Update to V15A8910 skip the dealer
