Transmission fluid change
Old 01-19-17, 05:11 AM
texas008
texas008's Avatar
in this service, not all transmission fluid is replaced,
this price is probably for less than 5 quarts,
Originally Posted by pinoyesv6
i checked with my dealership and its $195 to replace the transmission fluid. to do the service yourself you'll need a case of fluid which runs a little over $100 a case. so in this case, at least for me, i'd really consider just having the dealership do it, sip some hot cocoa while they do it and have in my service records that they were the last ones to touch the transmission.
to do it or not do it, its like an insurance policy. some people have it and have that piece of mind while others don't and just deal with whatever happens when it happens if it happens.
as for fluid if you do decide to do it yourself, I personally was on the fence between WS and Amsoil ATL since I run Amsoil on my other vehicles. After looking up the cost of getting it done at the dealer, i've decided to let them just do it when the time comes.
GraySteel (04-08-21)
Old 04-29-18, 10:16 AM
Acrad
Super Moderator
Acrad's Avatar
Received 3,562 Likes on 2,332 Posts
Using your phone for the 120 or so degree temp check point will be a lot easier than even having TS hooked up and/or the method you can make the drive indicator flash when it hits 120.
https://www.clublexus.com/forums/gx-...s-via-obd.html
Old 06-03-18, 08:10 PM
southpaw85
southpaw85's Avatar
Default Transmission fluid and more
Hey everybody, acquired my first Lexus last month and have been reading the forums before and after my purchase.
I bought a high mileage, but well taken care of 2012 gx. 154,000 miles.
It ran ok, but I’ve put about $1,200 into 8 new spark plugs, a fuel system cleaning and a transmission fluid change.
The transmission fluid change made the biggest improvement in smoothness. My Lexus dealer service department said it’s pretty much a 100,000 mile fluid and mine had never been changed. They said it was getting nasty. I mentioned my hesitation in getting the service because of the sealed transmission. They unequivocally said it will benefit the vehicle. I know, money for them, right.
For those who are convinced it’s not necessary, I probably won’t change your mind, but for those not sure, I can tell you it absolutely made transmission shifts smoother and the ride enjoyment that much better.
The following 3 users liked this post by southpaw85:
GraySteel (04-08-21), jszachar (02-02-21), tomscnj (03-04-24)
Old 06-04-18, 12:18 AM
pcp123
pcp123's Avatar
Clean looking ride for one with that many miles. Curious how much did you pay? What was the transmission flush price by itself? Was thinking of doing one myself.
Old 06-04-18, 04:35 AM
southpaw85
southpaw85's Avatar
Thanks, It’s in good shape for sure. I paid $17,800 for it. The kbb was 20k even with the mileage but it had been on the lot for a while.
The transmission fluid change was $224 out the door at the Lexus service department. The spark plugs and the fuel cleaning service was the bulk of my expense.
Old 06-05-18, 02:46 AM
NewB2Lexus
NewB2Lexus's Avatar
How much fluid did they bill? Are you sure it was a complete flush or just a partial fluid change? I don't think the dealer will do a complete flush rather they just drain and replace the fluid which may be only a fraction of the total. If that's the case you might want to repeat this service another 1-2 times, few ks driving between, especially if the old fluid was nasty.
When our '15 gets there in age or milage i will absolutely do drain-fills on the transmission, the sealed for life is only good for the warranty period. If you want to keep the truck running beyond that you have to maintain the transmission.
MB backtracked on its sealed for life transmissions in the late 2000's recommending trans service every 40k.
Old 06-05-18, 10:01 AM
Romanova
Romanova's Avatar
Welcome aboard, great pick up! Should serve you well for years to come. Our 2012 is about to hit 112k... need to get the tranny fluild and the brake fluid done. On yours, you should consider the front and rear diff as well as the transfer case if they have never been done. There is a great write up on this forum and they are all really simple to do. https://www.clublexus.com/forums/gx-...id-change.html
Old 08-19-18, 07:46 AM
Acrad
Super Moderator
Acrad's Avatar
I'd think of this as a general overview video of dropping AT pan and swapping filter and partial fluid change.
Old 08-21-18, 04:18 AM
zanka2010
zanka2010's Avatar
https://www.youtube.com/watch?v=YpRrNgJkmXo
Does that method require the transmission to reach operating temperature first?
Old 08-21-18, 08:44 AM
R3loader
R3loader's Avatar
Has anyone completed the full tranny flush using the method in the Tundra above?
Old 08-21-18, 01:47 PM
Acrad
Super Moderator
Acrad's Avatar
Important part with operating temperature is making sure proper fill level with the overfill open. I've seen the precision on this all over the place to no one checking to getting it down to the droplet every 15 seconds it seemed. I frankly don't know for sure if one needs that level of precision. I'd have a hard time believing that an extra tablespoon of fluid was going to be the difference between a proper fluid change and future problems. Just my opinion though on the latter.
Old 10-20-18, 03:39 PM
Acrad
Super Moderator
Acrad's Avatar
I'm gonna venture into doing some drain and fills.
Buying a case of fluid
I'm somewhat averse about mixing fluids so just gonna use stock Toyota WS fluid. I realize it may not be the best but new fluid is better than nothing.
Wmb67 (05-29-22)
Old 11-16-18, 07:14 PM
Acrad
Super Moderator
Acrad's Avatar
These tend to last longer than a simple change but ordered some of the drain gaskets.
PN: 35178-30010
Old 11-17-18, 05:25 AM
Acrad
Super Moderator
Acrad's Avatar
460 AT Fluid Instructions
The following 5 users liked this post by Acrad:
cancruiser (05-11-22), Chasin (11-20-19), jphowey (07-23-21), Philly01 (05-06-23), thiggins (08-29-20)
Old 11-17-18, 05:35 AM
Acrad
Super Moderator
Acrad's Avatar
A member of GXOR changed fluid at 26.6K miles on his '15. Look at the color of the fluid. Good fluid color should be the pink.
https://www.facebook.com/photo.php?f...55741842970143
Quick Reply: Transmission fluid change
