DIY, Door Sill Dent Solution/Options.
This is my GX in the driveway for needed pressure to seat the sill plates with my mod
Standby for updates... Yea, this is a tease
Sorry for the delay. Lots of pictures here so a long thread.
Back siill plate support bought at Home Depot.
Front
Used a heat gun and putty knife to pull them up. They are on there pretty good. I was a little rough removing them.
Scuffed up the plastic to get a good stick.
Filled the dents with this.
Sanded down.
support plates installed.
Bought several options to choose from
Temporarily wrapped with options.. Nope...
Nope..
The black 3M carbon fiber wrap blends in better and I think it would do better at hiding current and future dings
GE silicon.
I used a hard and a soft brush along with the heat gun to fill in the LEXUS.
Had to cut the front support.
Using the Home Depot plate did raise it up a bit.
Finally got around to the passenger side a month or so ago.
I did not use the Home Depot plates on this side and I wouldn't use them if I were to do this again. I think this black carbon fiber wrap will conceal dings pretty well. As you can see this eliminated the gap I have on the driver side. Not sure how I got the gap on the rear, I guess I should have centered it.
This is my driver side today that was installed 2/28/2016 it looks the same as when installed.
Front
Sanded down.
Nope..
GE silicon.
Super Moderator
The lit factory ones of mine have a few small dents....not feeling worth the $300+ to replace though.
a11179a
11-28-17 06:10 PM
GS3Tek
GX - 1st Gen (2004-2009)
28
08-11-08 10:54 AM
