40 psi for all tires?
Old 06-19-16, 01:40 PM
paui4m
paui4m's Avatar
35 here as well.
Same on my 4R which also recommends 32.
paui4m is offline
Old 06-19-16, 04:00 PM
tecman
tecman's Avatar
Originally Posted by LXGXSAM1
...perfect ride for me, no more bounce around, ride almost feel like the GS lux.
How does 38 PSI give you a less bouncy ride when the truck calls for 32? I have 22" wheels and I am running them at 32 PSI and it rides rough. Maybe I should drop down to 28.
tecman is offline
Old 06-19-16, 06:53 PM
LXGXSAM1
LXGXSAM1's Avatar
Originally Posted by tecman
How dose 38 PSI give you a less bouncy ride when the truck calls for 32? I have 22" wheels and I am running them at 32 PSI and it rides rough. Maybe I should drop down to 28.
The 20" rims and 285 tires
LXGXSAM1 is offline
Old 06-20-16, 04:05 AM
CdeFabio
CdeFabio's Avatar
I run 40 psi with stock wheels measured cold year round.
CdeFabio is offline
Old 06-20-16, 01:23 PM
jtrue28
jtrue28's Avatar
40psi in the winter is a bad idea.
jtrue28 is offline
Old 06-20-16, 10:02 PM
LXGXSAM1
LXGXSAM1's Avatar
Unless it is a Michelin.
LXGXSAM1 is offline
Old 06-21-16, 04:22 AM
CdeFabio
CdeFabio's Avatar
I always have Michelin tires. I do not particularly like having to add air to my tires when it is 0F degrees outside because the low pressure light is on. I have used 40psi on each GX I have owned, no issues, good gas mileage and more responsive handling. The BMW dealer we use for my wife's BMW loves to lower the pressure on her tires when we take it in even though I tell them not to so that the first cold snap we have she is complaining the low pressure light is on....
CdeFabio is offline
Old 06-23-16, 08:53 AM
Craigyyy
Craigyyy's Avatar
What makes it even worse is that they're lowering the hot pressure to the doorjamb recommendation. So when the tires cool off you end up way underinflated.
Craigyyy is offline
Old 06-24-16, 04:46 AM
CdeFabio
CdeFabio's Avatar
Yea, to me the info on the door jam is just a recommendation based on basic tires in the OEM size. I never go by that, way to soft of a ride with lots of body roll, bad gas millage and tire wear on the outside edges. I always use the tire manufacture specs and common sense based on the temperature and load. On the flip side, you don't want too much pressure or your will start wearing the middle part of the tire tread.
CdeFabio is offline
Old 06-24-16, 10:26 PM
LXGXSAM1
LXGXSAM1's Avatar
To me, wearing out the middle part is better than wearing out the outer part of the tire, but most importantly, by inflating my tires at least 4psi more allows me up to 3mpg gain on freeway driving.
As an example of my mpg on city/local roads around Carlsbad, CA (up/down hill, curvy, and rough asphalt roads), with average speed of 30 mph.
OEM tires and wheels @32 psi (cold): 12.5 mpg
OEM tires and wheels @36 psi (cold): 13.8mpg
Aftermarket wheels and tires (20" forged wheels/285/50/20 tires) @ 38 (cold): 14.5 mpg
I am still collecting my data on new tires for freeway driving, therefore it's TBD.
LXGXSAM1 is offline
WolfyLS460
Hybrid Technology
06-27-17 12:54 PM
Hulk311
Wheels, Tires & Brakes Forum
06-20-15 03:46 PM
blk_lex_gs
05-22-06 10:53 PM
Morrissey
01-21-06 03:12 PM
Quick Reply: 40 psi for all tires?
