Re: Window Trim / Grill blackout
Old 10-02-15, 07:12 PM
bigsley18
bigsley18's Avatar
Originally Posted by goaliemask
Bigsley:
I tend to agree on the pricing...
Problem is the PlastiDip even with the glossifier doesn't get the look I want in certain areas.
Vinyl gets the look I need (Gloss) in areas but can't be done as easily it in all reas.
Hmmmm.?
Tecman:
Looks good.....
Vinyl or Plastidip? How long has it been done? Holding up?
Front windows and Drone Mobile starter installed the day after I bought it.
GoalieMask
GoalieMask-
Why not just do both? I know it won't be as uniform, but only you will know. For example, you can plastidip the emblems, chrome accents on the grill and window trim. And the larger, more noticeable areas like grill surround and trunk pieces can be vinyl wrapped. Just an idea.
bigsley18 is offline
Old 10-02-15, 07:45 PM
goaliemask
goaliemask's Avatar
Think ur right bigsley........ I agree. Think that may be the best plan.
goaliemask is offline
Old 10-02-15, 07:48 PM
tecman
tecman's Avatar
tecman is offline
Old 10-02-15, 10:47 PM
goaliemask
goaliemask's Avatar
Here is a quick mockup I did............ Gloss black on larger ER outside chrome. Black inserts on grill? Matte or Gloss on inserts? Emblem either PlastiDip or black pearl.
Mockup...... Back end Black Gloss vinyl around Plate, PlastiDip emblems or possibly the black pearl ones?
Mockup...... Matte Black vinyl around window. Gloss black on lower door moulding on door handles. Thinking about roof rack but may hold off.
Old 10-02-15, 10:49 PM
goaliemask
goaliemask's Avatar
Thoughts?........
Suggestions?
Old 10-03-15, 08:26 AM
bigsley18
bigsley18's Avatar
Thoughts?........
Suggestions?
GoalieMask-
If you have disposable income, by all means, get those emblems. But no way are they worth $300 in my eyes. That could easily go into other mods, such as the nav hack. Honestly, I think you should start out small. So get some painters tape and a black can of whatever rubberized spray of your choice. If you don't like it, simply peel it off. Just make sure you do enough coats so it's easier to remove.
I purchased anthracite metallic plastidip and did my wheels and rear emblems. I did my front emblem but I messed up the prepping and didn't like the way it turned out. But the anthracite matches the front grill because it's sort of gunmetal. I believe there are tutorials on mixing and/or layering different colors and metallics to achieve different finishes. So you could possibly add a metalizer(???)
Old 11-03-15, 04:03 PM
YashK
YashK's Avatar
Default Plasti Dipped Grille
Hi, I plasti dipped my grille black. I put 3 coats of glossifier to make it glossy and it looks amazing. Here are some pictures:
Attached Thumbnails Re: Window Trim / Grill blackout-img_5475.jpg   Re: Window Trim / Grill blackout-img_5476.jpg
YashK is offline
Jamodah (01-25-21)
Old 11-05-15, 12:41 PM
Dr. Jekyll
Dr. Jekyll's Avatar
Never said paint.......
Vinyl / PlastiDip. If I didn't like it it's removable with no issues. I tend to disagree though. Too much chrome on this thing......
Is plastidip easily removable? Does it need to re reapplied over time?
Dr. Jekyll is offline
Old 11-05-15, 05:31 PM
YashK
YashK's Avatar
It is can be removed very easily if wanted. It stays on as long as you want it to. I highly recommend it. I also did my rims with plasti dip
Attached Thumbnails Re: Window Trim / Grill blackout-img_5139.jpg
YashK is offline
BLambo
02-11-19 05:50 AM
RealMCR12
RC - 1st Gen (2015-present)
18
07-10-16 01:48 PM
zmoneyJD
06-23-15 09:44 AM
bfrd
10-02-13 08:13 AM
unccballa
12-24-10 08:43 AM
Quick Reply: Re: Window Trim / Grill blackout
