Beatsonic Navigation Bypass
For my 2015 GX460 premium with OEM Nav, I got the Beatsonic 6223 module installed byon of their local authorized dealers. The issue I am facing is when I input the address while in motion and hit go, the Navigation freezes. I have to switch the Bypass off again for the Navigation to resume. Is it normal for this model or installer did not install it properly or its a bad unit.
Anyone who has this unit installed on 2015, please share how it works on their vehicle.
Thanks
Thanks
Thanks
Thanks
That's the way it works on my 2012. It's the way it has to work because what you are doing when you turn the switch on is telling the system that you are stopped so it's not tracking you properly. It can take almost a mile at times to figure out where you are once you turn it back off. Completly normal. I have made a switch on a couple other of my vehicles and it works the same.
I used the beatsonic and used a Roku box and stream video via hotspot to the screen in the dash.. Works like a champ...
My toyz
Is your GX premium or Luxury? So what I understood is you hookup your roku with the AC plug in rear and but how you stream via hot spot? Can you please explain a little further. Thanks
Also, is it possible to watch DVD on in Dash Navigation screen. My GX is premium with Nav not luxury without Rear entertainment system (Rear DVD).
Thanks in advance for help
