Need a rear mat suggestions?
Old 03-21-15, 05:28 PM
Passat774
Passat774's Avatar
Default Need a rear mat suggestions?
I need a rear trunk mat for my truck. My issue is that I have the third row seat split 50/50. Should I buy a factory mat and just cut it? Where the seats separate?
Do I have any other options?
Passat774 is offline
Old 03-22-15, 08:45 AM
pinoyesv6
pinoyesv6's Avatar
I have the same issue.
What I will probably end up doing is getting some rubber blacked carpet from the home center and cutting that up. Its going to take a little bit more work than cutting a factory mat but it will cost hell of alot less.
pinoyesv6 is offline
Old 03-22-15, 04:01 PM
tecman
tecman's Avatar
Buying a custom GX mat and cutting it is not practical. The high cost and the required modification with cutting the custom fit would compromise the outer seam or molding look.
I think a general mat would fit your need better.
I have a mat in my GX that is made for a garage.
I think this is it.
http://www.lowes.com/pd_345720-73825...mat&facetInfo=
I expected to cut it, but turns out it was not necessary for my application (it covers the entire rear).
This type of mat allows a cleaner look when cutting is needed.
tecman is offline
Old 03-23-15, 09:12 AM
fortytwo
fortytwo's Avatar
I think this is it.
I like this idea - thanks for the tip!
fortytwo is offline
peasept
LX - 3rd Gen (2008-2021)
14
05-04-23 03:52 AM
aussie1
GX - 1st Gen (2003-2009)
03-06-10 10:37 PM
Kash
03-26-04 02:19 PM
Quick Reply: Need a rear mat suggestions?
