Nasty rattling near idle/when cold, year 2......
Old 01-31-15, 07:43 PM
SecPole14
SecPole14's Avatar
Exclamation Nasty rattling near idle/when cold, year 2......
So this is the second winter I've had my GX (a 2014 purchased in Nov. 2013).
With radio and other accessories turned off, there is a rattling/grating sound that is quite pronounced at/near idle, especially when cold. Sounds like a rapid PRAPP-PRAPP-PRAPP. This occurs when the vehicle is in Drive, but stopped. Occurs most often at within the first 5 minutes of operation....i.e. leaving the house or office, driving to the end of the street, hearing it at a stoplight or stopsign.
I've posted videos/recordings of it previously, which I have also shown to the dealer. The dealer said they could sort of reproduce, but could not diagnose it. I have tried to crane myself outside of the GX to listen to it, but from outside nothing seems to be amiss.
At first I was worried that it was engine knock/the car eating itself, but if that noise was representative of that, I think the car would be blowing smoke or dead by now. I have not noticed smoke, adverse effect on fuel economy or the noise at speed/under load, as you would expect if the engine were truly knocking. So I'm thinking it may be a fan, some type of underhood accessory, etc. that is the culprit. Sounds almost like a plastic component (fan, pulley, etc.) could be off kilter?? Something that more or less goes away after the engine has fully warmed up and the car has been driven for 10 mins or so.
So 2 questions:
1) Anyone experience this, or similar?
2) Would anyone (in a cold climate, from a cold start) be willing to take a couple minutes to take a close listen and see if their GX behaves as described above under similar conditions the next time you drive it?
Many thanks!
SecPole14 is offline
Old 02-01-15, 09:03 AM
SecPole14
SecPole14's Avatar
I'm thinking it might be a bad/out of spec idler pulley or belt tensioner.
Old 02-01-15, 01:49 PM
Craig B
Craig B's Avatar
No noise on my 2014...
Craig B is offline
Old 02-01-15, 04:34 PM
ohiois350
ohiois350's Avatar
My car don't make any noise when it stopped, but it make like rattle noise behind the speed cluster gauge when speed around 30-35mph at sound weird but it goes away after pass 40mph.
ohiois350 is online now
Old 02-08-15, 08:04 AM
craigrpete
craigrpete's Avatar
Default Extra Noise when Cold
I can confirm I hear a fairly loud "raspy" noise when it's been cold out (say below 40) and the engine is cold. By the time I leave a parking lot it's gone. I just think it's the normal higher revving all trucks do to warm up initially.
Should watch the RPMs to see if the noise corresponds to higher revving when cold.
craigrpete is offline
alder8
GX - 2nd Gen (2010-2023)
12-22-15 10:55 AM
trombs
GX - 1st Gen (2004-2009)
15
11-04-14 09:30 AM
flyfishman
16
05-31-09 02:36 AM
LexusBob
05-22-07 02:58 PM
Lvangundy
03-21-03 09:40 AM
Quick Reply: Nasty rattling near idle/when cold, year 2......
