120 VAC Power Outlet by Rear Door Hinge
Our 2010 base model GX 460 was 'born' in November 2009 and purchased new in February 2010, but we never used the 120 VAC power outlet at the back of the cargo compartment by the rear door hinge. I was cleaning and swapping 'summer' floor mats for 'winter' mats and decided to see if the outlet works. The appended pictures prove it does produce 120 VAC .... actually, almost 124 VAC, but I have no way to test if it can supply 100 Watts, much less the waveform shape. Perhaps it could light a 100 Watt incandescent bulb, but nothing sensitive to supply line glitches!
Regards,
SaniDel
Regards,
SaniDel
Sanidel,
I would not expect to run a CRT television, or a microwave with it. As it was not designed or intended for it. I do run my Apple TV with it, I charge the camcorder with it, and I run a thermostatic igloo cooler with it as well.. That's been about all the uses I need for it so far.
Handy item for sure, deathly in need of it that I would pay for it as a solo item, no.
Randy B
Randy B
MX5NES350
01-06-18 08:28 AM
shhhua
11-29-10 12:57 PM
