High pitch sound when cruising above 70 mph - Club Lexus Forums
Thread Tools Search this Thread
Old 03-03-13, 10:46 AM   #1
Teddyofind
Default High pitch sound when cruising above 70 mph
My 2013 GX makes this noise when I step on the gas padel when the speed is 70 mph or higher. It is not very loud but noticeable, even with the radio on. I noticed this these past two days on highway. There is no such sound during local drive or speed below 70. It sounds like it came from the engine compartment, but I am not 100% sure. Is this normal? Could it be from the wheels or chassis? My truck only got 1800 miles after 2 months driving.
Teddyofind is offline   Reply With Quote
Old 03-03-13, 12:19 PM   #2
SaniDel
SaniDel's Avatar
You're already driving at 70 MPH ... and accelerating, right? Are you really surprised to hear more engine noise in that situation? That's the "sound of power" ... you have to temporarily increase engine output to accelerate, but it should decrease when you are at a higher constant speed ... and decrease further as you slow.
Here's an experiment. Use your cruise control so the GX tries to hold a constant speed regardless of load and take a road trip with plenty of upgrades and downgrades. That should be easy in Pennsylvania, especially as you head west. Turn off the radio and listen to your engine ... it should be loudest going uphill, less on level ground and even less going downhill.
If you have the transmission in 'D' it will try to keep in top (6th) gear, but it will unlock the torque converter and eventually downshift if it can't maintain speed. Driving the Pennsylvania Turnpike on cruise control will demonstrate this.
What octane are you burning? Could it be you are hearing the engine nocking on too low an octane? We've had many discussions about gasoline, but if you burn premium and especially from a "Top Tier" retailer you shouldn't hear knocking.
http://www.toptiergas.com/retailers.html
Regards,
SaniDel
SaniDel is offline   Reply With Quote
Old 03-03-13, 02:20 PM   #3
Koz
Is this noise new? Take it to the Stealer, let them take a look. If they say it's normal, ask for a ride in a demo model.
Koz
Koz is offline   Reply With Quote
Old 03-04-13, 11:33 AM   #4
Craig B
Don't know if you have cross bars on the roof? My QX4 had whistle noise on the highway and it was from
the bars on the roof. I don't have cross bars on my GX 460 and I don't have any noise at any speed.
Craig B is offline   Reply With Quote
Old 03-04-13, 11:50 AM   #5
Eppieguy
Quote:
Originally Posted by Craig B View Post
Don't know if you have cross bars on the roof? My QX4 whistle noise on the highway and it was from
Good Point, My Tahoe did the same until I took them off, my friends Pacifica does it too, drive me nuts.
Eppieguy is offline   Reply With Quote
Old 03-05-13, 06:28 PM   #6
Teddyofind
Regards,
SaniDel
The noise is there when I step on the gas panel and when speed is above 70mph, no mAtter I keep constant speed or accelerate. I tried this morning and it is suprising that when the speed is above 80, the noise is gone or nearly unnoticeable.
Yes, I mostly filled up with Sunoco 93 octane gas. So it is safe to say it is not the gas that is causing it. I will try the cruise control method sometime when I got a chance.
Old 03-05-13, 06:38 PM   #7
Teddyofind
No I don't have crossbar on the roof.
Old 03-27-14, 07:55 AM   #8
SecPole14
SecPole14's Avatar
Teddy, any update??
My 2014 does the exact same thing. I think it may be due to the intake/throttle design, something at that speed just happens to produce a certain sound (that higher pitched howling/whistling).
It is a little bit reassuring that others have experienced the same thing. Has it caused any further issue?
SecPole14 is offline   Reply With Quote
Old 04-20-14, 06:23 PM   #9
LDCSteve
Gear whine, they all do it at different speeds. This is my third GX, they are all noisy, my 2014 expedition is quieter at highway speeds and handles better, wont do another GX.
LDCSteve is offline   Reply With Quote
Old 04-20-14, 06:35 PM   #10
T4Fun
T4Fun's Avatar
i am still clueless what you folks are hearing. my gx is very quiet on highway, even at 80 mph
T4Fun is offline   Reply With Quote
Old 04-20-14, 08:27 PM   #11
GX4704ME
Quote:
Same here T4Fun! My GX is also quiet.
GX4704ME is offline   Reply With Quote
Old 04-21-14, 12:36 AM   #12
Kdash106
Kdash106's Avatar
My 2014 gx is very quite at all speeds, Does 2013 have the wind deflector by the side mirror?
Kdash106 is offline   Reply With Quote
Old 04-21-14, 11:00 AM   #13
Quadro
I have 2013 and I have no such noises.
Quadro is offline   Reply With Quote
Old 04-21-14, 11:55 AM   #14
MyGX460
MyGX460's Avatar
My wife GX 14' made all kind of noise .. So disappointed for $60k vehicle ...
MyGX460 is offline   Reply With Quote
Old 04-21-14, 02:12 PM   #15
Herd72
Herd72's Avatar
So far my '13 sounds very much like the Sequoia I had before only quieter over all. I did notice a whine while coasting on a road trip but I am pretty sure it was the road surface in VA because as soon as I hit NC in one direction on WV in the other the whine disappeared. The pavement in that part of VA was sort of an odd pinkish color so I think that was it. Sort of sounded like snow tires in the summer.
Herd72 is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
whining semar LS - 3rd Gen (2001-2006) 4 11-20-16 04:50 PM
2011 GS350 'hooting' sound at 60mph deltabravo GS - 3rd Gen (2006-2011) 10 10-16-16 03:54 PM
GSF Wind Noise Rrgirgis GS F (2016-present) 6 05-27-16 10:54 PM
Intermittent Steering Wheel Vibration GS4hunnit GS - 2nd Gen (1998-2005) 11 01-08-16 03:23 PM
What is this humming sound.....?. satiger GX - 1st Gen (2004-2009) 7 03-27-15 06:32 AM
Tags
2011, 6th, 70, 80mph, avobe, downshifting, driving, gx460, hear, high, lexus, ls430, makes, mph, noise, pitch, sound, whem
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright © 2000-2016 Internet Brands, Inc. All Rights Reserved
  • Ask a Question
    Get answers from community experts
What's your question?
Send
