Got rid of the GX!!
Old 02-03-12, 05:02 AM
  #31
wannaGX
wannaGX's Avatar
Originally Posted by markrivers
^ hey i drive a Range Rover.. ergo i'm "all Man"? but i also like driving our RX 350.. i guess yo can call me "Bi"? ha ha!
and i see a lot of GX 470/460 Blizzard pearl being driven by the "XX" population.
the same way i see a lot of Tahoe, Suburban, Ford Expedition being driven by moms..
Guys, if you base your manliness on that truck you drive.. then you have bigger issues.
by the way, my friend who served 3 tours in Iraq and Afghanistan drives a Prius.. does it emasculates him? hmm i don't think so.
My husband drives a prius and I drive a GX. Never thought about what that says about our dynamics. . . .
wannaGX is offline
Old 03-03-12, 08:51 PM
  #32
V8_Fan
V8_Fan's Avatar
Originally Posted by NC244GLT
That probably would have made a huge difference in my opinion of the truck. We did take the white one to a local shop and he put it on his rack and said it was in perfect alignment, but it still pulled and had the wheel cocked to the left when going straight. I thought it was a really nice truck inside and it looked pretty good outside, but it just drove poorly. She doesn't need a truck, but didn't want to listen to me when I said that in December. I've made a few regretable vehicle decisions in the past, so we'll let it slide!
I had what may have been a similar problem w/ my 03 LX470 when I bought it in '06. The steering wheel was about 10 deg to the left when driving straight. The alignment was good, as if I let go of the wheel, the truck would drive straight. It turned out that the VGRS ECU (variable gear ratio steering, first year the LX had it) had been updated in subsequent years. Replacing the ECU solved the problem. Another problem that could affect new vehicles is the crummy tires Toyota puts on their new vehicles (usually Dunlops instead of something decent like Michelins). Sometimes, a bad tire causes a vehicle to pull one way. It certainly happens if you don't cross rotate and keep rotating front to rear like 99% of dealers do.
V8_Fan is offline
Old 03-04-12, 01:17 PM
  #33
Koz
Koz's Avatar
The reason a steering wheel is not centered and the alignment is good is because the the steering was not centered and locked before the alignment was done. A bad tire usually causes vibration not pulling to one side.
Koz
Koz is offline
Old 03-04-12, 01:38 PM
  #34
Craig B
Craig B's Avatar
A tire could have a slipped belt and can cause the vehicle to pull.
Craig B is offline
Old 03-05-12, 05:30 AM
  #35
Koz
Koz's Avatar
A shifted belt could cause a pull but should also get a mean vibration. If the vehicle pulls it is usually the alignment or a damaged steering component.
Koz
Koz is offline
Old 03-05-12, 01:43 PM
  #36
shaolin
shaolin's Avatar
it could be just the alignment tech. My previous IS250 was off and Tustin & Newport Lexus couldn't fix it. I end up taking it to a racing alignment specialist and he was able to fix it without doing computer alignment.
Of course, I got my alignment done (for IS350) there right after 250, and so far it's been good for at least 40k miles.
I guess if I do end up getting this GX I will have to bring it to him right away...
shaolin is offline
Old 03-06-12, 04:32 PM
  #37
Koz
Koz's Avatar
I replaced the useless OEM summer tires and wheels on my IS with less then 1K miles on them. I had the alignment checked and it needed adjustment. I plan on getting LTs for the GX (for 2013) and will have the front end checked. I have 12K miles on the OEM tires (at 40 psi) and they are wearing perfectly. If you get a GX and it rides perfectly straight with no vibration and you keep an eye on how they are wearing, you shouldn't need an alignment.
Koz
Koz is offline
Old 03-06-12, 05:09 PM
  #38
SaniDel
SaniDel's Avatar
Our early-production (November 2009) 2010 base version GX 460 runs smooth and true on the original Michelin Latitude Tour HP tires with over 20,000 miles. Our dealer swaps them front to rear every six months ... otherwise, all we do is keep them at 40 PSI.
It has been discouraging to read that other owners are having problems with vibration, but if Koz's and our experience is any indication, it is specific to vehicles and not general to the model. It may be difficult to find and it depends on the capability of who is providing service, but the problem can be fixed as several posters have reported.
Regards,
SaniDel
SaniDel is offline
Old 03-07-12, 07:02 AM
  #39
gs400jon
gs400jon's Avatar
Regards,
SaniDel
Here, here. Have had zero problems with my GX running on Michelins. Swapping factory tires for the Michelins was part of my purchase agreement.
gs400jon is offline
Old 03-29-12, 06:27 AM
  #40
evo8
evo8's Avatar
i drive a Range Rover HSE so when we went Lexus shopping last Aug 2011,
OT, how do you like your 2010 RRS hse? joined this forum way back in 2009 when I was looking for an SUV/car to replace my rolled over evolution IX MR. looking at the "green" RX450h but ended up buying a cadiallac escalade hybrid. just bought a new 2011 RRS hse(last of dealer stock) and looking for aftermarket accessories hence bumped on this site again
drove the GX as well but was swayed by the initial insurance testing as well as it sits tall driving.
evo8 is offline
Sam524
RX - 4th Gen (2016-2022)
14
09-22-18 12:01 PM
Lurker9
05-08-18 12:09 PM
kevs98GS4
04-07-14 03:19 PM
Mdkellys
RX - 3rd Gen (2010-2015)
01-13-11 02:51 PM
KA8
GX - 1st Gen (2004-2009)
05-11-09 10:14 AM
Quick Reply: Got rid of the GX!!
