Valentine 1 Hardwire Question
Old 09-22-11, 11:08 PM
bsjoiner
bsjoiner's Avatar
Default Valentine 1 Hardwire Question
Hi guys I just bought a new GX460 last weekend and need to have my Valentine 1 installed. I purchased a BlendMount (fits perfectly) and I also purchased one of the Stealth Cords to have it hardwired into the rearview mirror. Can anyone tell me which wires on the rearview mirror wire harness plug and the positive and negative (the colds do not make any sense). I don't know how to use a voltmeter so any help would be appreciated.
Thank you
Brandon
bsjoiner is offline
Old 09-23-11, 09:13 AM
Craig B
Craig B's Avatar
I had my dealer wire mine...
Sorry I couldn't help...
Craig B is offline
Old 09-23-11, 10:42 AM
Koz
Koz's Avatar
Set the meter to DC volts (approx 15 volt range) and attach the black lead (of multi-meter) to a good ground (any metal brace or bolt). Then just touch the red lead to the wires in question. You will get approx 12 volts when you find the right wire.
Koz is offline
Old 09-23-11, 06:00 PM
Luke27617
Luke27617's Avatar
Hard wire (tap in) to the cigarette lighter and then easily you can find a place for stealth display to mount near by. I don't have my GX anymore so cannot show pictures but may have posted one in DIY.
Luke27617 is offline
Old 09-24-11, 04:45 AM
rockydog
rockydog's Avatar
This is what I did. Tapped into the lighter with a t-tap (radio shack) and ran a phone wire inside the passenger side "A" pillar, then in the front of headliner. Undetectable and when I sell/trade the GX I just remove the wire.
rockydog is offline
Old 09-27-11, 06:14 AM
Luke27617
Luke27617's Avatar
Congrats on an easy install!
Old 08-15-12, 08:59 AM
MickeyS
MickeyS's Avatar
I did my Valentine One hard wire to the fuse box using a "add-a-fuse" tap. Grounded the negative wire and connected the positive to the tap that went into the p/outlet in the fuse box, it took me 20 minutes, no splicing of the gx's wiring.
I know the only thing I need is a Blendmount. I don't know if they make one for the 460, the 470 is in their data base, don't know if the GX470 has the same kind of mirror or post as the 460.
MickeyS is offline
Old 08-16-12, 10:04 AM
Eppieguy
Eppieguy's Avatar
Does anybody know how the pillar cover comes off? I'm going to run my wire up the cover to behind the mirror.
Eppieguy is offline
Old 08-16-12, 02:06 PM
rockydog
rockydog's Avatar
You don't have to remove the cover. If you're running it from the cig lighter, run it up the weather stripping near the door, tuck it under the "top" of the pillar cover, then tuck it under the headliner until you reach the mirror. Use a popsicle stick or a plastic trim tool to tuck it. This is how I did it and it's invisible.
rockydog is offline
Old 08-16-12, 06:06 PM
Eppieguy
Eppieguy's Avatar
Thanks, I am going to add a circuit to the fuse box and run it up the drivers side and up. I guess I'll see how it goes.
Eppieguy is offline
Old 08-17-12, 05:23 AM
Koz
Koz's Avatar
Make sure you tap a circuit that is only powered when the ignition is on. There is usually a circuit you can tap off right in the rear view mirror column/cover.
Koz
Koz is offline
Old 08-17-12, 06:11 AM
Eppieguy
Eppieguy's Avatar
Koz
Yup, thank you very much.
Eppieguy is offline
Old 08-24-12, 10:09 PM
MickeyS
MickeyS's Avatar
I forgot to mention that you could buy the "savvy" from Valentine Research and all you have to do is plug it into the OBD port of your GX. It was so easy and it gives you the added benefit of an extra port for your V1 and the mute feature that you can use when traveling at different speeds.
MickeyS is offline
basacowan
RC F (2015-present)
04-24-18 08:01 AM
socaligs
01-09-17 09:02 PM
jaxxx
12-22-10 11:49 AM
mikeru25
10-23-08 06:18 AM
Quick Reply: Valentine 1 Hardwire Question
