Cruising range after fill up!
I noticed recently that when I fill up my tank with 20 gallons the cruising range shows only 308 miles as opposed to 330 or even 340 miles when I first got the truck. Should I be concerned or is this normal? Is there a way to reset it so it goes back to the way it was before? Could it be that I put more air on the tires? I went from 32psi to 36psi. I remembered when I disconnected the battery on my 4runner it used to reset, I don't know if you can do the same with the GX. Also, would there be any difference in performance if you drive with the "eco" off?
I had assumed that the estimate of cruising range was based on current/average mileage. Presumably, the cruising range estimate will change as your driving routine changes and your mileage changes. Inevitably we all drive a certain routine and only changing that will change the estimate, but perhaps over the upcoming end-of-year holidays your routine may be different enough that you will notice a change.
Regards,
SaniDel
Regards,
SaniDel
xRYD3Rx
05-20-13 03:28 PM
