Official 2nd Gen GX Modification (DIY) Thread!!
Old 04-21-10, 08:41 PM
  #91
Luke27617
Luke27617's Avatar
Originally Posted by antonio98
Luke,
Can you post a pic with the 5K parking lights?
Will take a picture when I get the truck back. The dealer wanted to keep it overnight as they didn't have a chance to work on it today.
Old 04-22-10, 06:39 PM
  #92
ybing
ybing's Avatar
You doing your recall already @@?
Old 04-22-10, 06:44 PM
  #93
Luke27617
Luke27617's Avatar
I will do the recall next week. I am doing the 1000 miles free check and as well couple fit and finish items. Want to make sure those are taken care of before I install Valentine 1 this weekend. I don't want to be blame that I did it when installing the RD. The replacement part will arrive around lunch tomorrow so should have my car back tomorrow. Will take a picture and post tomorrow night. Also wanted for lexus to check my vibrating hood at higher speeds and bumps. They compared to other new truck and had the same effect. So Lexus consider this as no problem, but they have reported my concern back to HQ.
Over the weekend will post DIY for radar detector for conceled display install and also I am installing chrome side moldings. Weather will not be the best, so perfect timing for doing things in the car.
Old 04-23-10, 05:12 PM
  #94
Luke27617
Luke27617's Avatar
Luke,
Here it is the pictures of parking lights with 5k bulbs against HID lights. HID are brand new so they look more yellowish (will get whiter within first 100hrs of use). Also parking lights came out a little whiter than actually those are, but gives you an idea. Pakring lights give a nice warm white color which matches very closely the HIDs.
Attached Thumbnails Official 2nd Gen GX Modification (DIY) Thread!!-img_3516.jpg
Old 04-23-10, 07:34 PM
  #95
ybing
ybing's Avatar
I already have 3000 miles on my car, and I'm going to Cali tomorrow, another 500+ LOL, the 1K check up is kind of waste of time, I work at the dealership before and I know that They stop doing 1K service if you buy your car after March
Old 04-23-10, 07:36 PM
  #96
ybing
ybing's Avatar
I just wondering, the v-LED is 27mm long, how much clearance left from the edge? The pucto one is 35mm long, I not sure will it fit or not, for the running board, door panel, and rear parking light. I think the front parking light will work...
Old 04-23-10, 07:49 PM
  #97
Luke27617
Luke27617's Avatar
Took a closer look today. Dome lights should support the Putco 360 without any problems. Also the flat board type should work as well. Since the support is limited, I would go with the 360. Parking lights and puddle lights may not work as the clearance seems to be limited. Doors may work, but it would require removing a clip. I may do some testing soon. Will post pictures and review.
Old 04-23-10, 08:23 PM
  #98
antonio98
antonio98's Avatar
I used the single bulb Putco 194 LED's for my running board lights and they fit with no problems.
My interior bulbs are v-LEDs.
Old 04-23-10, 08:27 PM
  #99
Luke27617
Luke27617's Avatar
What are your impressions of v-leds vs. Putco? Color, quality,etc.. Can you post a picture?
Old 04-23-10, 08:29 PM
  #100
antonio98
antonio98's Avatar
Yep, that's what I need. Thanks!
Old 04-23-10, 10:47 PM
  #101
ybing
ybing's Avatar
So the front parking light don't have too much room?
Old 04-24-10, 07:10 AM
  #102
Luke27617
Luke27617's Avatar
It seems like it as I always fighted to put the bulb there. you can see through the lens when on like is or almost is touching the wall (it goes in at an angle)
Old 04-24-10, 11:19 AM
  #103
ybing
ybing's Avatar
Maybe i should just get the normal one for that, the rear one should have more space right?
Old 04-24-10, 12:24 PM
  #104
Luke27617
Luke27617's Avatar
I didn't bother with the one in the rear since it doesn't do much. I have replaced the parking lights as they give this ugly yellow collor forward. For the parking for sure I would go with the 5k v-leds when those come back in stock.
Old 04-24-10, 05:32 PM
  #105
Luke27617
Luke27617's Avatar
Default Light in inside door handles
While installing my Valentine1 with conceled remote, I have noticed that inside the car, door handles have a light . I want to replace the bulbs there as well with LEDs. I am sure it is simple, but doesn't anyone know how to open the door handle? Don't want unnecesarily put scratches trying to figure out how to open.
Quick Reply: Official 2nd Gen GX Modification (DIY) Thread!!
