Official 2nd Gen GX Modification (DIY) Thread!!
Old 11-04-10, 03:14 PM
  #151
Luke27617
Luke27617's Avatar
Originally Posted by snair84
Sorry T4Fun. Just joined the forum today and had already purchased the Philips LED DRL.
Luke, thanks for the pointers. I installed the DRL's and I really like them.
Congrats! Post some pictures. I have not seen Philips in action yet.
Old 11-10-10, 05:08 AM
  #152
CaptMarty
CaptMarty's Avatar
Default Mirror Mounted Radar Detector??
Has any purchased one of the: BlendMount 2000 Series Mount for Valentine One radar detector, BV1-2000A that is advertised on this site. $89.95
I'm just a little concernerd about the additional weight on the mirror mount. I'm sure the cost of replacing the mirror if anything happend would be outragous.
Thanks
Old 11-10-10, 05:46 AM
  #153
Luke27617
Luke27617's Avatar
Thanks
I have considered buying that one. Weight shouldn't be an issue. I decided not to but it as the radar is asking to be stolen, cops can see it easily and of course people seating on your a$$ as they see that you have one. I have mounted my V1 to the right of mirror at the top of the glass. To cover suction caps I have put a small strip of darkest tint behind it. You have to look very closely from outside to see I have something there. Of course I am using the conceled display as well.
Old 11-15-10, 08:39 AM
  #154
woson25
woson25's Avatar
hello, is there a way to install a kit for auto folding power mirrors jus like on the lx 570???
Old 11-18-10, 08:04 PM
  #155
MickeyS
MickeyS's Avatar
I love the running board mod, what is the bulb number and where can I get it? I really want to make the bottom lights much brighter, is this mod just an even swap of bulbs?
Old 11-18-10, 08:20 PM
  #156
Luke27617
Luke27617's Avatar
It is a simple bulb swap to LED. Board, doors and vanity lights all use the same bulb called 194.
For board buy this
http://www.v-leds.com/Exterior-LED/C...85865-1-2.html
You will need two sets
For doors and inside vanity
http://www.v-leds.com/Interior-LED/G...04828-1-2.html
You will need 6 sets. Those are a little longer and will not fit in board ligting.
For parking lights, I use those
http://www.v-leds.com/Interior-LED/D...64848-1-2.html
For turn signals. You will need to buy load resistors as well to convert to LED turn signals
http://www.v-leds.com/Exterior-LED/P...34404-1-2.html
Backup lights
http://www.v-leds.com/Exterior-LED/P...26829-1-2.html
Use coupon code VISION for additional 15% off on top of current sale. The code should be good until end of the month.
Old 11-20-10, 10:28 PM
  #157
MickeyS
MickeyS's Avatar
Thanks for the information, I'm heading to the website to order some of those cool bulbs.
Old 11-21-10, 01:00 PM
  #158
MickeyS
MickeyS's Avatar
I am afraid about breaking the cover on the dome and door lights. What's the best way to remove the covers without breaking and/or scratching the surroundings? Can you post pictures of how to remove the dome lights? I would really appreciate it!
Old 11-21-10, 04:05 PM
  #159
Luke27617
Luke27617's Avatar
Use a small flat screwdriver to pop it out inside lights. Look at post 5, 10 & 29 for pictures.
Old 11-27-10, 11:43 AM
  #160
MickeyS
MickeyS's Avatar
I got the interior bulbs today and installed them, however the the door bulbs were bigger than the original so I couldn't put back a clear cover that was there before. Should I order a smaller bulb for the doors or just leave it without the plastic cover? It is the same bulb however the LED is longer and it won't let me install that other clear plastic housing.
Old 11-27-10, 01:17 PM
  #161
Luke27617
Luke27617's Avatar
I completely forgot about the length of bulbs in doors when providing suggestions above. Sorry about that. You should be able to install them without the interrior small covers. If you want to keep the covers, I would exchange them for the same type but shorter which I recommended for exterior door steps.
Old 11-27-10, 08:31 PM
  #162
MickeyS
MickeyS's Avatar
Talking
It's ok, I'll order the smaller ones and keep the others as extras in case I need more. Which bulb goes in the doors, the same one that I used for the running boards? Before I forget, thank you for the mod, the lights look really nice and I love the white color, it's much brighter! Now, I'll do my wife's ES350 and my daughter's Maxima.
Old 11-28-10, 06:16 AM
  #163
antonio98
antonio98's Avatar
Yes, the same bulbs you used for the running boards will work in the doors and allow you to put the clear plastic cover back on.
Old 11-28-10, 07:54 AM
  #164
MickeyS
MickeyS's Avatar
Thanks, how long do the LED bulbs normally last? Are there any options for the DRL's in LED?
Old 11-28-10, 02:43 PM
  #165
antonio98
antonio98's Avatar
Since the DRL's are also the high beams, LED's are not recommended.
You may want to check this thread.
V-LED's has high quality bulbs. I would expect them to last for years. I've not had any problems thus far.
Quick Reply: Official 2nd Gen GX Modification (DIY) Thread!!
