GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Heater Vent Issue 2006 GX470
Old 12-15-16, 08:38 PM
wombat55
wombat55's Avatar
Default Heater Vent Issue 2006 GX470
Noticed today in the cold Chicago weather that my heat was only coming out of the dashboard vents rather than the floor vents whether the climate controls were set to auto (supposed to default to floor) or manual. Had the car into the dealer last week for the recall to replace the center airbag sensor assembly. Anything involved with the airbag sensor replacement that could have messed with the heater/climate controls? Is there any computer reset that needs to be done after disconnecting the battery for the service? I did the A/C self diagnosis test and it cycled through all of the settings and vents and gave the all clear 00 code. Thoughts?
Old 12-16-16, 12:00 PM
chiph9
chiph9's Avatar
If you can use the climate controls to manually direct air to the floor, then the duct door motor is fine.
Use the Auto setting, then go to the Climate screen and it should show you where it's directing air.
Chip H.
Old 01-07-17, 07:13 AM
wombat55
wombat55's Avatar
When I manually direct the heat to just the floor in the climate control or leave the heat on Auto (which shows it defaulting to just the floor in the climate control) the heat/air comes out through the vents. As I mentioned earlier, the A/C self diagnosis suggests all is OK and doors are functioning (unless that is only testing the A/C and not the heater).
Lveyolfe
10-10-17 05:07 PM
hovbuild
RX - 3rd Gen (2010-2015)
12-28-14 04:38 AM
satnav
02-24-14 04:43 PM
Lexs400
Maintenance
03-26-05 06:08 PM
soj17
11-23-03 06:11 PM
Quick Reply: Heater Vent Issue 2006 GX470
