GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Broken E-brake handle on 2007 GX470
Old 11-30-16, 07:58 PM
maxse
maxse's Avatar
Default Broken E-brake handle on 2007 GX470
Went with a different car. Thank you anyway
Old 12-12-16, 08:48 AM
cardboy008
cardboy008's Avatar
Mine on my 03 is broken too, anyone have any ideas?
Old 01-10-17, 04:48 PM
TheDeep
TheDeep's Avatar
can you explain? Does the handle make 'click' sounds as you pull it up? Does it prevent the wheels from moving? Does it stay locked in the UP position unless you push the button?
In my 2007 gx470, the handle works - it rachets up and holds the wheels but it won't stay in the UP position. If i let go of the handle, it just drops down. I am looking for a fix too...
Old 01-10-17, 05:38 PM
cardboy008
cardboy008's Avatar
I have the same problem, there aren't that many click sounds, but it does grab the brake. Once I let go of the arm, it drops down. Also the button comes back out slowly, I'm going to wd-40 that part and see if it helps any.
iogden
ES - 5th Gen (2007-2012)
07-28-20 01:41 PM
JSTALEX
10-11-15 11:45 AM
obturator
06-14-15 05:51 PM
TommyR
13
04-07-11 12:12 PM
Lohus
02-02-10 11:32 PM
Quick Reply: Broken E-brake handle on 2007 GX470
