greasing zirk fittings for u joint and slip yoke
I believe there are 6 zirk fittings, 2 u joints for the front and one slip yoke and 2 u joints for the rear and 1 slip yoke. I am aware the the u-joints get grease until it comes out the sides, and that the slip yoke should not be overgreased. However, I can't find a difinitive pic on where each one is located so I don't mix them up?
There's no possible way to mix them up, it will be obvious when you look under there. The u-joint fittings are literally in the middle of the u-joint itself. Sometimes they can be at a difficult angle just because of the position of the driveshaft when you parked. If they are too difficult, roll the vehicle a little.
es30000000
12-04-12 07:56 PM
Horsepwr
03-05-10 09:10 PM
