12v accessory plug
12v accessory plug
just purchased an 08 and noticed the 12v accessory plug that's next to the seat heaters doesn't work. Checked the fuse it's fine. Suggestions?
It might have gotten disconnected underneath.
Chip H.
Chip H.
Did you check the fuse with an ohm meter or just look at it? Just sayin', ohm meter is the sure way. Also, double check to be certain you are looking at the correct fuse.
Mike
Mike
