Radio Does not power on
Got in truck today. Radio would not go on. Got in the truck a few hours later, radio worked. Has anyone had this happen to them?
A nuisance but here's a quick fix, turn your GX 470 Off for a minute and then turn back On- should fix problem. Lexus is aware but won't take accountability.
When it's cool out no problem- operates as normal. Hope this helps.
Took the L in for service at the dealership.....after having the L serviced and got in it in the service area..NO SOUND AT ALL...went right back inside and told them that the radio was working fine when I arrived and now no sound....Dealership replaced the ML AMP! Hassle free! But it is a common problem with the ML amp and Lexus Corp is well aware of that issue but will not tell you!!!
Amp that powers speakers- has internal overheat switch. If it gets too hot outside and the cabin gets too hot as result turns the amp Off.
rscharf
07-06-08 09:21 AM
