05 gx470 a/c cycling
Hi!
A/c wasn't as cold as I remembered this year. I added just a little of some old frion i had and no difference. Bought a new can w gauge, which showed below range. Filled to range and compressor/fan would cycle on for 3 seconds and off for 3 seconds. Thinking the Guage was at fault, I took out some Frion and it worked. After about 20 minutes of driving it would start cycling on/off but for longer periods...the vent temp would get warm for several minutes and the come back to a decent temp for a few minutes. Before i go diving into issues (checking sensors, flushing frion) I hoped someone had seen this problem and knew how to fixed it.
Thank You!
Thank You!
Hi!
Thank You!
Thank You!
Some cycling is normal, so that the expansion valve, etc. don't ice up. But I agree - double check the pressures.
Chip H.
Chip H.
foreste1
GX - 1st Gen (2003-2009)
05-06-17 08:57 AM
drvinh
07-13-15 12:42 AM
