Coolant reservoir overflow leak
Make sure you have the heat blaring on full hot when burping, so you get all the air out of the heater core.
Yes, when I burped the system, I had the heat of full blast with AC off. I even revved it to about 2500 RPM which seemed to help coolant circulate through the system. Then I topped everything off and went on a drive, all of the coolant came back out of the reservoir.
I went and got the system pressure tested today, everything came back fine. I might take it down to another shop by my work tomorrow and have them take a look. I'll report back after that.
Best case scenario: clogged radiator or broken / improperly installed thermostat. I'd lean toward this unless the previous owner ran it dry completely until it stopped.
Put some clean cardboard down in your garage and park your vehicle over it. If you have a leak, you will see the water/coolant stains in the morning.
Chip H.
Chip H.
