GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
P0420
Old 06-29-16, 04:47 PM
hopk1719
hopk1719's Avatar
Default P0420
I know this code has been talked about on the forum a little bit. This code was thrown on my 04 gx470 (112,000). I reset the check engine light buy unplugging battery. It pretty much came right back on. After trying to reset a few time, I replaced 02 sensor downstream driver side. Light went right off on start up. No check engine for about 1,000 miles. Now check engine back on with same code? Is this just a coincidence with O2 sensor keeping light off for a month, and my Cat is bad as well? Any insight would be appreciated.
Old 06-30-16, 06:29 AM
chiph9
chiph9's Avatar
A downstream sensor code is telling you there's a problem somewhere upstream. Check for other codes, check that the catalyst is still good (not broken into chunks), check for a cylinder that is running rich (bad spark plug, bad ignitor, etc).
Chip H.
Old 06-30-16, 06:39 AM
hopk1719
hopk1719's Avatar
Thanks Chip. I just bought OBD reader to look at it a little more. Both upstream A/F Sensors had been replaced by Lexus before i bought it. I know if I take to dealer they will tell me to replace Cat. Everything seems to be running absolutely fine.
Old 06-30-16, 06:40 AM
sheikhmax
sheikhmax's Avatar
Factory Manual for Troubleshooting.
Check the Monitor Description for DTC.
File Type: pdf
Old 06-30-16, 12:14 PM
BlackCat81
BlackCat81's Avatar
It needs a cat.
Old 06-30-16, 01:06 PM
hopk1719
hopk1719's Avatar
You sure it is the cat? Should I have replaced both downstream o2 sensors at the same time? I only did bank 1, or does it not matter?
Old 06-30-16, 02:04 PM
BlackCat81
BlackCat81's Avatar
It doesn't matter only doing one O2 sensor. You can try installing a spacer on the rear O2, it should help slow its response and trick it to thinking the cat is doing a better job. It's a bandaid, but it could work for you.
Old 06-30-16, 02:05 PM
chiph9
chiph9's Avatar
If you don't have a scope to look at the waveforms per the diagnosis PDF that sheikhmax attached, check the sparkplugs on that side and check that the ignitor is in good shape. Tap/shake the cat to see if it rattles (it shouldn't). If you can (not sure how easy this is - haven't tried it myself), unbolt the cat and look down in it to see if the grid is intact (not broken, not melted/clogged).
Also check for good wiring on the sensors (that it hasn't been chewed by squirrels).
If all of that is good, seek professional assistance.
Chip H.
Old 06-30-16, 04:48 PM
BlackCat81
BlackCat81's Avatar
Chip H.
A bad coil would cause a misfire, a bad plug would cause a misfire, wiring damage would cause a specific code related to the component it's affecting. It needs a cat.
Old 07-01-16, 05:50 AM
chiph9
chiph9's Avatar
OP hasn't mentioned if other codes were set. And checking those is cheap and easy.
Chip H.
Old 07-01-16, 07:37 PM
hopk1719
hopk1719's Avatar
I will be checking for other codes tomorrow. If no other codes, I will be trying an o2 spacer. Just bought the vehicle 2 months ago and still need to do timing belt/water pump/ thermostat
Old 07-02-16, 08:33 AM
hopk1719
hopk1719's Avatar
Voltage at idle? Shouldn't bank 2 sensor 2 be a flatter? That is an original o2 sensor.
Old 07-02-16, 12:17 PM
hopk1719
hopk1719's Avatar
I keep seeing bank 2 sensor 2 really volt spiking. The replaced sensor seems to be operating properly.
camera
06-12-12 03:43 PM
mr3gs300
Maintenance
12
02-06-12 11:25 AM
UR2slow88
11-19-10 08:09 PM
Max Power
08-19-09 05:51 AM
Bud
RX - 1st Gen (1999-2003)
12-12-07 11:46 AM
Quick Reply: P0420
