GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
radio cuts out at high volume
Old 05-13-16, 07:13 AM
melcoeb
melcoeb's Avatar
Default radio cuts out at high volume
03 GX470 w/ ML/Nav, weird radio problem - the radio cuts out at high volume, and only at high volume. It cuts out for 1 sec, then comes back, then cuts out, then comes back. Screen is on all the time while this happens, and occurs with all inputs - AM, FM, dvd. These are what I've done to diagnose so far:
1) disconnected battery for 10 minutes, no joy
2) replaced 2 fuses pertaining to radio, no joy
3) took out cd in dvd player, no joy
Here's what's weird: When I move the balance to have all/most of the sound coming from the rears, it doesn't cut out! See attached pic. I am able to get it to the 3rd line below the lowest; if I go above this line, it starts cutting out.
I did replace both front speakers a month ago, and was working fine all this time.
Bad amp? Bad front speakers?
I'd appreciate any help with this, guys, thanks.
Old 05-13-16, 07:17 AM
MikeFoxx
MikeFoxx's Avatar
Amp is on its way out same thing happened on my GS. It would happen more in the summer hot weather... pushing volume high and when the amp got too warm or hot it shut off till it felt it was ready to join the party again.
Old 05-13-16, 07:21 AM
melcoeb
melcoeb's Avatar
well, crap, that's not good. Thanks for the diagnosis, though.
Old 05-13-16, 11:16 AM
chiph9
chiph9's Avatar
Yeah, I was going to say overheating too.
Chip H.
Old 05-13-16, 11:33 AM
melcoeb
melcoeb's Avatar
I don't believe it's the heat/overheating, since it was 65 degrees this morning, and I was only driving for 10-15 minutes. I do not hear any chirping (seems to be a symptom of amp failure). I'm going to try disconnecting the 2 new front speakers then play with the balance, see if it makes a difference.
Old 05-13-16, 11:37 AM
MattJO
MattJO's Avatar
What impedance are the new speakers? Maybe it is pushing the amp to a lower OHM, thus a higher load than it is used to and making protection kick in?
Old 05-13-16, 11:43 AM
melcoeb
melcoeb's Avatar
8 ohms. I used the ones that a lot of GX owners used as replacements. Here is the amazon link, I bought the 350w version:
Amazon.com: DS18  MB69 350 Watts Mid-Bass Speaker, Set of 2: Car Electronics Amazon.com: DS18 MB69 350 Watts Mid-Bass Speaker, Set of 2: Car Electronics
Old 05-15-16, 02:44 AM
melcoeb
melcoeb's Avatar
after inspection, the electrical tape insulation i put on the wires going into my left front speaker wasn't very secure and came off, contacting the metal on the door, causing the radio to cut out. Scotchlocked the wires, and all is good now. Whew! Glad I didn't have to spend the $$$ to get the amp repaired.
Old 05-15-16, 08:06 AM
chiph9
chiph9's Avatar
Rather than Scotchlock connectors, look into heat-shrink tube over a soldered connection. The Scotchlock connectors go bad over time because of vehicle vibration, and corrosion if they're exposed to the outside.
Chip H.
Old 05-18-16, 09:11 AM
melcoeb
melcoeb's Avatar
Chip H.
thanks for the tip, will do that the next time around.
IS3502006
11-30-17 09:18 PM
macho6868
06-17-15 12:55 PM
Tdvlexo
12-14-13 06:29 AM
acenase
10-09-07 01:24 AM
indigo4298
01-20-07 08:58 AM
Quick Reply: radio cuts out at high volume
