LED lamps
LED lamps
Is it possible to replace all front/rear lamps esp. the headlights with LED ones? I find the headlamps so dim - almost can't even tell they're on sometimes.....
To make matters worse, after driving my 2015 LS460 FSport and 2016 LX570, it feels even dimmer when getting into the 05 GX470...
LED isn't going to be as bright as HID.
www.XenonDepot.com has the best kit around; a lot more info in this sticky:
https://www.clublexus.com/forums/gx-...diy-guide.html
How yellowed/cracked are your headlight lenses? I just replaced mine with new OEMs and there was a major increase in the light hitting the pavement afterward.
Chip H.
Chip H.
If you feel like a project.
This kit works remarkably well. Get out your drill and you just progress through the different grit sandpapers until you seal the headlight. I've seen them work miracles.
http://www.walmart.com/ip/19794453?w...557752&veh=sem
Former Sponsor
@AustinHusk - I would suggest going with an H11 HID Kit for maximum light output. LED will be an improvement to your stock halogen bulbs, but if you are looking for the best possible light output, I would suggest going HID.
Steve
Steve
+100 on Xenondepot HID kit--I have his Kits on my GX (low beam and Fogs) and WOW what a difference Plug and play and tons of light, you will not regret the purchase. I suggest to get the 5K HID kit, very bright white light output
Another fan of my Xenon Depot HID conversion kit here.
Thanks for all the feedback! Really appreciate it.
I was looking at Amazon.... and my heads still spinning after seeing this
http://www.amazon.com/s/ref=au_pf_cr...2A0D8WCRP14Z8F
Hard to explain but I would say it has about average yellowing/scuff marks. Where did you get the OEM's from?
Ordered them from a dealer in Atlanta - they had a very good price. (can't name them, as they don't advertise here)
I could have saved even more ordering some of the Chinese-made clones, but there were a lot of stories about leaks.
Chip H.
Chip H.
Which H3 kit did you go with? The Volt?
http://www.xenondepot.com/H3-HID-Kit...D-p/vdp-h3.htm ?
I'm interested in doing fogs.
