GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Gx470 center bore questions
Old 03-13-16, 06:53 PM
shyguyF
shyguyF's Avatar
Default Gx470 center bore questions
Hi folks!
Can someone confirm 2006 Gx470 center bore specs ? I tried to search that but some said our truck's center bore is 108.1mm, the others said 106mm so I do not know which one is the right number. Since I have just ordered a set of wheels that hub size is 110.1mm but the wheels does not come with the hub centric rings. I need to know the exact number so that I can order a set of hub rings.
Thanks in advance!
Old 03-14-16, 08:25 PM
shyguyF
shyguyF's Avatar
Hummmm nobody know ? Ok i maybe take one wheel off and measure it.
Old 03-16-16, 09:21 AM
NR04
NR04's Avatar
106mm. If you're looking for after-market wheeels, you will be hard pressed to find the correct bore size. I just got Method wheels and they are 108mm. I'm using Gorilla lug nuts which center the wheel and not using any hub rings without any issues.
Old 03-16-16, 09:54 AM
shyguyF
shyguyF's Avatar
Thank you NR04 for the info ! I am having no time to take the wheel off to measure. What Gorilla lug nuts part number are you using? I ordered the Gorilla 91137BC lugs but I don't know if this is the right ones ? Saw some members here got the 91137BCB. Hopefully mine is working .
Old 03-21-16, 10:20 AM
NR04
NR04's Avatar
I got the 21134ETBC Black 12mm x 1.50. It has the regular cone shape but has an extended thread which slides into the wheel (hence helping the wheel align without being hub centric. I believe this is the model most Toyota owners are using. Got them at Amazon for $54 for 24.
Ecohman
03-02-17 02:43 PM
vtrusty
05-25-11 05:40 AM
njumongkol
02-14-11 12:50 PM
djsai
06-28-10 06:46 AM
pvo
Wheels, Tires & Brakes Forum
02-08-04 11:15 PM
Quick Reply: Gx470 center bore questions
