Hi, cheapest bluetooth audio option on my 06 navi gx 470?
Old 03-11-16, 09:58 PM
mrdoitall
mrdoitall's Avatar
Default Hi, cheapest bluetooth audio option on my 06 navi gx 470?
Hi guys, i have a module in there for aux but it tweaks sometimes it works sometimes it doesnt sometimes it says external system not connected?
So im kinf of fed up with it, i would like bluetooth on my 06 gx470 ( it has stock navi No sat ) what is the cheapest option for bluetooth audio , parrot 9000 ?
Or can my module be fixed maybe ? It seems like every 6 monthe i have to reprogram it .. kinda fed up with it
Old 03-12-16, 11:13 AM
djspock303
djspock303's Avatar
http://gromaudio.com/ i don't know about the cheapest but its an another option. Others like Parrot as well.
Old 03-12-16, 11:54 AM
aljodoro
aljodoro's Avatar
Default Using the Grom in my 2006 non nav system
I have the Grom USB and Grom IPD3 (Btd). I do not like it in the least. It is very problematic to get it to connect at times but that is not all.. Worse yet when it doesn't want to connect if I use some of the trouble saving techniques offered by Grom the radio will go into a mode where there is no audio. It will operate as designed, change to cd, tape or radio stations but there is no audio output. The only way to deal with this is to pull the fuses under the hood for the radio (there are two) and wait from 30 minutes to a couple of hours. One good thing pulling the fuses always does work. Unfortunately this is a hassle and sometimes it takes overnight for whatever is the issue to purge itself.
I have tried a half dozen different Bluetooth devices and it seems to be a problem with the Grom product. I have yet to figure out the sequence which can cause the problem. It happens about 50% of the time. I tried writing down every step I took but there seems to be no correlation between steps.
I do not recommend the unit I have with a non-nav 2006 GX..
Old 03-13-16, 06:46 PM
djspock303
djspock303's Avatar
Who hooked yours up?
Old 03-13-16, 08:42 PM
mrdoitall
mrdoitall's Avatar
I bought the car like that, and ive already reset the module 2 times.. it just keeps going crazy after 6 months..
Old 04-05-16, 12:14 PM
cgdrennan
cgdrennan's Avatar
I bought a Grom TOYNB3 (BT3) on amazon back in October for my '04 GX. It was a very straightforward installation. The BT3 supports bluetooth audio/voice calls so I had to run the included mic cable. I placed it just under the ignition. You can also buy cables to use ipod/iphone or usb connection. I have never had a problem connecting any of my devices following the included instructions. The audio quality is great and the hands free calling works great as well. Since you have an '06 I believe you already have bluetooth for voice calls correct? Anyway, I love the Grom product that I bought. Does exactly what I want and sounds great
bobbyfk
GX - 1st Gen (2003-2009)
06-16-18 07:12 PM
energie8
12-01-12 12:08 PM
Vic3038
01-04-04 05:43 PM
Quick Reply: Hi, cheapest bluetooth audio option on my 06 navi gx 470?
