VSC TRAC, VSC OFF and Check Engine lights with code P0057
Tonight, during a short ride, all the sudden the VSC TRAC, VSC OFF and Check Engine came on. Atfter home, I got the P0057 code from a OBDII scanner. The P0057 code indicates O2 sensor on bank 2 lower sensor. However, the interesting thing is I also lost the power seat adjustment on the seat memory. When I switched between L1 and L2 , the mirrors and the steering position changes and the seat did not. However, the adjustment buttons on the seat itself work correctly. I wonder if this problem associates with P0057? Anyone has the same issue?
Standard stuff I think -- Check for a blown fuse. Check for a weak battery. Check for a disconnected O2 sensor wire. Check that the catalyst isn't turning cherry red from heat.
Chip H.
Chip H.
Thanks for the comments.
Re-set the seat memory L1 & L2 today. It worked normally. It was weird to lose the seat position, but not the side mirror's and the steering column's yesterday. Ordered the O2 sensor today and waiting to see if it will fix the issue.
Sorry, no idea. Try asking in the ES forum.
Chip H.
Chip H.
Gomer1
RX - 1st Gen (1999-2003)
02-23-10 06:50 AM
99es300
17
07-17-06 08:11 PM
