GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Water too Deep
Old 01-06-16, 06:08 AM
jtrice
jtrice's Avatar
Default Water too Deep
Does anyone have an estimation of how deep water can be to safely pass in a GX?
Old 01-06-16, 06:58 AM
chiph9
chiph9's Avatar
Hmm. I don't know if the GX has remote transmission/differential breathers. But I would think that you could drive up to the wheel hubs if you weren't going too fast. If you were willing to do fluid changes afterwards you could probably go deeper, but then you'd be up against the height of the air intake.
There are people who have snorkles on theirs, so they can go quite deep.
As always - don't drive into flooded roads. Turn around, don't drown.
There was a lady here in Austin a few years ago who drove around a police car into a flooded road and was swept away.
Chip H.
Old 01-06-16, 12:17 PM
Craigyyy
Craigyyy's Avatar
Yeah, what kind of water are we talking about?
We get street flooding here in New Orleans all the time. Limiting factor is the height of your air intake, and whether or not you mind if the interior gets wet
Old 01-06-16, 03:23 PM
Stereorob
Stereorob's Avatar
im curious about this one too.. how deep? a foot? two feet?
Old 01-07-16, 06:29 AM
chiph9
chiph9's Avatar
There's more to it than just water depth. As you drive, you'll have a bow wave. And depending on where that lands on the vehicle, that's the height to worry about.
Chip H.
Old 01-07-16, 07:22 AM
IanB2
IanB2's Avatar
Chip H.
This is the real answer, if you're willing to go that deep is another issue, lol. On gas motors there's also your ignition system to be concerned with, there's some stuff that doesn't work so good if it gets wet.
Old 01-07-16, 10:39 AM
chiph9
chiph9's Avatar
I was thinking about the alternator, myself. It can probably tolerate a short immersion, as it has the cooling openings to drain water out. You'll get a charging-system light on the dash, either because of the water inside or because the belt starts slipping.
Chip H.
Old 01-07-16, 11:20 AM
tz693
tz693's Avatar
I could be wrong, I remember somewhere in the user manual mentions 50 cm (20 inches) deep.
Just found this:
If you drive through deep water over about 500 mm
(20 in.) in depth, put the vehicle height in the HI (High)
mode with the active height select switch and then
turn off the active height control suspension by
pushing the height control switch. Drive your vehicle
at 30 km/h (19 mph) or lower speed.
Old 01-09-16, 11:58 AM
BlackCat81
BlackCat81's Avatar
I've done roughly 3 feet of water doing creek crossings out west with no issues.
depechek
GX - 2nd Gen (2010-2023)
07-30-17 12:49 PM
AJ
11-20-06 08:47 AM
oogster
Performance
01-21-04 09:44 AM
Spartan
08-05-02 02:09 AM
Quick Reply: Water too Deep
