GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Which wheel do u think looks better on a White Gx??
Old 12-22-15, 09:06 PM
Tdorydahz
Tdorydahz's Avatar
Default Which wheel do u think looks better on a White Gx??
Hi I'm debating between these 2 wheels to be mounted on my white Gx, which do u think would look better?? 2015 TRD Pro gun metal or Fn 5 stars in bronze ??? Also what size tires is the largest i can mount on a 17 inch wheels without rubbing. The rim is 8.5 wide, thank you for ur opinion
Old 12-22-15, 10:59 PM
IncgntoLex
IncgntoLex's Avatar
The max tire size you can run will vary depending on the offset of the wheels you chose. I believe with the offset of the TRD wheels you can run close to a 33 inch tire with no lift and no problems. A lot of your limitation will depend on the width of the tire potentially rubbing on the upper control arm at the ball joint.
Old 12-22-15, 11:52 PM
micah360
micah360's Avatar
If I had the choice between the two, I'd go with the bronze. I think they would set-off nice on a white GX.
Old 12-23-15, 04:32 AM
BlackCat81
BlackCat81's Avatar
I'm partial to FN wheels, since I have them, but I think the only way to go (in my opinion of course) is to go up a size and use 18's.
Old 12-23-15, 07:10 AM
MomCar
MomCar's Avatar
Whatever you decide on, post a picture of the final product so that I can see. Because I'm also considering new wheels.
Old 12-25-15, 11:07 PM
Tdorydahz
Tdorydahz's Avatar
Thanks for the input!!
Old 12-25-15, 11:10 PM
Tdorydahz
Tdorydahz's Avatar
Thanks for tech input I'm gonna go with the bronze!!
Old 12-25-15, 11:11 PM
Tdorydahz
Tdorydahz's Avatar
Thanks I'm goin with the fns!!
Old 12-25-15, 11:13 PM
Tdorydahz
Tdorydahz's Avatar
Hi this isn't my car but I found this pix with the trd wheels on it, looks pretty sweet
Old 12-26-15, 04:40 AM
Matsui
Matsui's Avatar
This looks good, but not as good as how the GX looks with FN wheels. Look up pics of BlackCat's car. His ride looks amazing with those wheels.
Old 12-26-15, 04:54 AM
BlackCat81
BlackCat81's Avatar
Awww shucks! Thanks!
Old 12-28-15, 10:45 PM
Tdorydahz
Tdorydahz's Avatar
Your car looks sick!! What size tires did u run on those wheels??
Old 12-29-15, 04:47 AM
BlackCat81
BlackCat81's Avatar
285/60/18 Nitto Terra Grapplers. They rubbed a bit but a small amount of trimming took care of it.
Old 12-29-15, 07:18 AM
Tdorydahz
Tdorydahz's Avatar
Thanks bro!! Appreciate the help
Old 12-29-15, 12:58 PM
NR04
NR04's Avatar
I like the TRD wheels.... seriously contemplated getting them on my silver GX before deciding on Method. By the way, TRD wheels are 7" wide, not 8.5". Lots of Toyota people have complained but many have mounted 285's without any issues.
Quick Reply: Which wheel do u think looks better on a White Gx??
