GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
P0420 / P0430 - Where to Start
Old 11-13-15, 03:43 PM
Bzowk
Bzowk's Avatar
Default P0420 / P0430 - Where to Start
Hey Guys -
About 3 months ago, my check engine light randomly came on on my 2003 GX470 which has 200,000+ miles. I own a bluetooth ODBII adapter so plugged it up and received the following:
P0420 - Powertrain
Catalyst System Effciency Below Threshold (Bank 1)
P0430 - Powertrain
Catalyst System Effciency Below Threshold (Bank 2)
I cleared it out and it reappears within a few miles. Sometimes just one of the codes, but eventually both. After much research, it seems this can be due to faulty O2 sensor(s), a cat converter, and/or leak in exaust system. I can't afford to take it in to get everything fixed so have a question.
Where should I start? I found that our Advanced Auto has Denso sensors for $61.99 which fit. My plan was to purchase one, install it, then if I still get codes, move the new one to the other sensor. If no go then, should I purchase a 2nd one or go straight for the cat converter?
What do you suggest? Thanks!
Old 11-14-15, 03:45 PM
chiph9
chiph9's Avatar
Have you watched this?
IanB2 (10-31-22)
Old 10-30-22, 11:34 PM
3dreamer
1st Gear
3dreamer's Avatar
Originally Posted by chiph9
Thank you! thank you! thank you!
I was on track to replace the CATs to rectify the P0420/P0430 code on my GX.
Battery Terminal cleaning, Air filter, MAF sensor clean and PCV valve cleaning seemed to do the trick. Didnt even have to replace spark plugs.
Tau511
Performance & Maintenance
01-21-16 01:42 PM
waqas300
08-08-15 11:23 AM
EPayne42
01-30-15 04:21 PM
tbilisi79
11-15-14 07:40 PM
Quick Reply: P0420 / P0430 - Where to Start
