2005-GX470 - Air Ride Replaced -- STILL NOT WORKING
Hi All,
My air ride started giving a C1751 error. The non-lexus mechanic suggested that the sensors and compressor needed replaced. Since this was an intermittent problem, I waited, and had the Lexus Dealership do their testing. They said the same thing.
The cost of this "little change", if done by the dealership was to be $3,300.
My mechanic said they could do the same thing for $2,400.
They had also discussed a conversion to Shocks and Struts -- that should have costed around $800.
When I went to the mechanic to drop the car off, they said, a conversion kit did not exist for my car.
So, I went the $2,400 path.
Out of curiosity I checked via google if there was a conversion kit -- within 2 seconds, they said, there was in fact a conversion kit for my 2005GX470. By this time the mechanic had already installed the new parts - but they called Strutmaster to see if the kit was complete. Supposedly, there are parts that didn't come in the kit, and weren't available -- I think they said, the Computer Bypass?
So, picked up the car this morning. New parts installed (OEM from LEXUS), and within 10 miles, the air ride was NOT working.
Anyone have a clue as to what might be happening -- other than ineptness by my mechanic?
Hope you can help,
Thx,
T.
Hope you can help,
Thx,
T.
Oh man that really sucks... I was faced with a similar problem though with just my shocks. After much deliberation I went ahead with a Strutmasters kit (Rear Springs and Shocks) and Arnott shocks for the front.
I know of at least two conversion kits that have great reviews and apparently are complete and fit perfectly: Strutmasters and Arnott.
Anyway, for more details see my thread: https://www.clublexus.com/forums/gx-...uspension.html
Other than that - sorry for your trouble man. Take that thing back and let the Mechanic deal with it.
HMMMM/GRRR ... I think they lied to me about the shocks/struts ... soooo, this problem with the OEM is just making it worse. Was there any connecting/bypass of the computer system required when you installed your kit?
thx,
T
With 250k miles though I was fully prepared to just disconnect the fuse that controls that light anyway. Happy I didn't have to do it!
I did my rear spring conversion for less than $450 using the MetalTech kit and new FJ Cruiser springs. And that includes a set of $100 air lift bags that go inside the springs. There are no special parts to keep the lights off, you pull 2 fuses and disconnect the air ride module behind the drivers kick panel. Easy peasy.
Hi All,
Hope you can help,
Thx,
T.
Hope you can help,
Thx,
T.
I definitely think it was misdiagnosed. They probably didn't understand the system and just threw everything they could at it hoping something would stick. The idea that all the sensors and the compressor all went out at the same time sounds like someone fired up the parts cannon and still missed.
Not sure what the car's history was but the air springs failing from age are about 100x more likely to be at fault than the compressor or sensors.
Also,if I thought the compressor needed replacing, I would go look first for something at a salvage yard rather than going to a dealer for a new part. A more honest shop would have put that out as an option, especially since it's not that hard to swap out. That alone could have probably shaved a thousand dollars off the bill.
If after spending $2,400 you're still having the same problems and trouble codes, they owe you a full refund but my guess is they will say or do anything to not let that happen.
I really think the smart play for these SUVs as they get older is to go straight to a steel coil conversion if you're having any problems.
mafpolo
12-27-15 04:40 PM
