Don't use OEM 4runner springs for suspension conversion.
#46
I've been searching this whole Bilstein 5100 issue for a few days now between here, t4r, and ih8mud. My rear has failed (stuck in the highest position) and my front OEM shocks are worn.
I will most likely go with Bilstein 5100s but I just have a simple question regarding the rear - do I need the Metal Tech or Strutmasters conversion kits to be able to install the 5100s?
I was thinking of either 1. getting the SM conversion kit (comes with rear shocks and Eibach springs) and then maybe front 5100s w/ my current springs. I know this won't get me any lift in the rear. Or 2. maybe I should just get 5100s all around and maybe Toytec springs so the whole truck is lifted - would I still need the MT or SM kits?
Anyone with this knowledge please let me know!
Thanks
Thanks
#47
Thanks
Thanks
#48
Thanks! Ended up ordering the DIY Metal Tech kit, separately ordering the spring seat assemblies, Bilstein 5100s all around, front Eibach/Toytecs, and rear Toytec Superflexes.
Lot more reasonably priced that all OEM air suspension parts.
#50
Lazytik did you do the project yet?
Im in search of front and rear shocks for my 2004 GX.
Front springs as well. The rears i used the Arnott Convertion Kit back in 2012 0r 13 with no issues. I don't use any of the electronics hight and all that. Straight forward Shocks and Springs.
Do you any part numbers? Thank you
#51
[QUOTE=BlackCat81;9244821]They're great, no complaints at all. If I knew how well I'd like them I would've replaced the air bags with springs before the compressor went bad. Even pulling roughly 1,000lbs they don't sag much.
[/QUOTE
what is your front suspension measurements from hub to well and ground to well?
[/QUOTE
#52
[QUOTE=GreggyG;9599688]
no idea. Whatever stock is. Front suspension hasn't been touched.
#53
GreggyG
GX - 1st Gen (2004-2009)
08-29-16 12:04 PM
