GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Quick Questions about "Clunk"
Old 06-18-15, 08:02 AM
itsthelaw
itsthelaw's Avatar
Default Quick Questions about "Clunk"
I read through the sticky, but couldn't get a definite answer to these questions...
I have a new-to-me 2007 GX470 with 150k miles. Clunk sound doesn't always happen and is not that bad. It usually happens when I stop quickly, not on a gradual stop. 150k service was done 2k miles ago, so it might have been greased.
Will this cause any issues with the vehicle if drive shaft is not replaced? Is it just annoying?
Is there any chance that Lexus will fix on a vehicle with 150k miles?
I live about 3 hours away from dealer who has 15 pages of records on this vehicle and an hour from nearest Lexus dealer.
Thank you!
Old 06-18-15, 08:25 AM
OG Dada
OG Dada's Avatar
No need to replace the driveshaft. You just need to grease the U-joints. I've had that problem ever since we bought our GX, and the first time I greased the U-joints it completely disappeared. It's actually quite normal for 4x4 vehicles. Even Jeeps need their U-joints greased every 5k miles.
Old 06-18-15, 03:43 PM
rodeo360
rodeo360's Avatar
Odd response but I had a nagging clunk for a while and finally figured out it was that the jack (for changing the tires)
in the rear compartment had slightly loosened from where you wedge it under the metal plate. When I was braking hard and or accelerating fast it would wobble and hit the front and back of the compartment.
Old 07-09-15, 09:36 AM
techrep
techrep's Avatar
King is spot on here... even my 4runner did this...got to grease the propeller shaft
Old 07-12-15, 12:23 PM
vxphan
vxphan's Avatar
Unless you want to grease it and create messy stuffs. I just get used to with the clunk. I expect the clunk every times I stop and release the brake slightly, so it won't annoy me anymore.
Old 07-13-15, 08:36 AM
Rz500
Rz500's Avatar
You should also expect your u joints to fail prematurely. That will be an annoyance. There are grease zerks there for a reason. They should be greased at least every oil change.
fj40
12-27-16 08:44 PM
Teddyofind
GX - 2nd Gen (2010-2023)
09-19-14 08:10 PM
DSW
41
05-30-13 05:34 AM
evaleif
08-19-11 12:46 PM
tetra7
16
01-09-04 11:46 AM
Quick Reply: Quick Questions about "Clunk"
