285's on a stock GX
285's on a stock GX
Do you think these pro comps would fit my stock '06 GX470 without any mods?
PRO COMPS
LT285/70R17, RADIAL XTREME A/T
http://www.procompusa.com/tires-prod...2284&pqa=14126
PRO COMPS
Not a chance. I would think you would need at least a 2" lift to run 285s and then you may still need to trim or remove side steps. Do a search this has been covered many times. I would imagine there are a lot better tires than pro-comps for the same or less money. Goodyear duratracs, nitro grapplers or bfgs would be my choices for A/T tires. Check out tirerack.com for best prices and reviews. I'm running 265/70/17 duratracs (they run on the big side) with 2.5" lift and I love them. I do a lot of city driving and my mpg dropped by about 2, I could only imagine what heavier 285s would do.
I have 285's on my truck but it is lifted. It still took some trimming to make things fit and I still experience a slight rub now and again. I did the lift at the same time I did the tires so I can't say with 100% certainty but I'm pretty confident they won't fit. My previous tire was a 265/70/17 prior to the lift and that was pretty much maxed out. Even that took some trimming to prevent rubbing.
285s won't fit without any modification to the suspension height and wheels. I have 2" lift with 32" (265/70/17) tires. Had the tires mounted before the lift and there were definite rubs inside the wheel well. also, 285 will probably rub against the upper control arms. I have about 1/2" clearance with my 265. You will have to get either wheel spacers or new wheels with more aggressive offset/back-spacing.
Nice truck Rz500. Essentially what I'm trying to accomplish...
Do you think if I threw a 2" lift in just the front I could make 285's work? Any issues with the back tires?
Also, any plasti dip process pics? Are those the stock colour on those rims?
Thx!
Thx!
you need a 2" lift all around (lifting just the front would look funny now wouldn't it)
you need wheels with at least 10mm more offset than the stock wheels to not horribly rub the upper A-arm. stock wheels have a 25mm offset.
Aftermarket rims make it much easier to fit these tires in relation to the upper A-arm, but the Tundra split 5 spokes and some FJ cruiser's have 17" factory wheels with a +15mm offset which helps quite a bit.
I did 2.5" lift and 285 tires on tundra wheels which have a 15mm offset, vs the stock gx 25mm offset, and that was enough to make it fit and not touch the A-arm except slightly under full compression.
I also had to trim the front fender plastics and cut a triangle out of the inside front of the side steps.
caster was thrown to the lower extreme due to the lift and factory A-arm, in the future I will be getting aftermarket upper A-arms for more clearance and more caster adjustment for alignment to get it back to perfect specs. with the lower caster it drives fine, but is slightly twitchy at higher speeds, feels better than most toyota trucks still to me.
I ran my truck with tricked out sensors but ultimately ripped them out and replaced them with coil springs. Much better. Plus, if you plan on doing any off-roading, a few people have reported their air bags popping out under full articulation with tricked out sensors. This was the main reason why I replaced them with coils. Didn't want to find myself with no rear suspension in the middle of nowhere.
for more offroad usage I would do coilovers in front and swap the rear to FJ coils and bilstein shocks, but for now I am rocking a leveling 2.5" spacer and tricked the rear airbags 2"
Right, but it's the width of the tire that rubs, not the height. So if the offset is correct, he should be able to get away with it in theory at stock height. My truck will be in Moab in August so we'll see how mine works out at full stuff and extension.
